Drivetrain Noise maker/hot side muffler delete. Quick, easy cheap.
Old Jan 18, 2016 | 07:06 PM
MartinR56's Avatar
MartinR56
Guys,
Quick and easy way to increase flow in your turbo plumbing!
Noise maker delete...
This is the noise maker.
Buy this from Lowes...
Cut the tube and insert
Hot side muffler delete...
2" OD aluminum pipe
Before and after!
Done! No obstructions in your air flow. About $15...
Old Jan 18, 2016 | 08:18 PM
cguzz's Avatar
cguzz
Nice job!
Old Apr 10, 2016 | 03:19 PM
GrayGhost's Avatar
GrayGhost
Genius, I just paid $70 for an aluminum pipe with a sticker. I might just sent it back and go to the hardware store. Thanks for the great and simple idea.
Old Apr 12, 2016 | 06:51 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
Nicely done. +1 for ingenuity and rollin up the sleeves. However, if the 2" tube doesn't have them already make sure to take the pipe and have a bead rolled on the ends. If the tube is cut straight it will blow off. Just one of those when, not if kinda things.
Old Apr 14, 2016 | 08:32 PM
hidperf's Avatar
hidperf
Here's a cheap way to bead roll your tube. I did mine this way and it's been perfect.
http://www.clubcobra.com/forums/tech...ad-roller.html
I also used one of these to block off the noisemaker hole. Can't remember the exact size I bought, but it was a PITA to put in, but it and the bolt will not fall out. FYI, make sure the bolt comes through from the inside and the nut is on the outside. That way, if the nut comes loose, it doesn't fall inside your engine.
Old Jun 18, 2016 | 07:17 AM
bugeye1031's Avatar
bugeye1031
Moderator
Napa has this part for $3.79. My local store had to order it because it is not a size they carry. The part number is 600-4004 and the name on the box is "Core Hole Plug". The number under the bar code is 19495 57533 7. I installed mine when I was walnut blasting the intake valves and it took a few minutes. I've had it on for a few weeks and have had no issues.
Old Jul 28, 2016 | 06:33 PM
bugeye1031's Avatar
bugeye1031
Moderator
Follow up -
I put in my rebuilt turbo a few days ago and this plug popped out on the highway on my way home tonight. Had to get towed the rest of the way. I'll find another solution....
Old Jul 28, 2016 | 07:13 PM
hidperf's Avatar
hidperf
Follow up -
Was it just a stock turbo?Curious, how much boost were you hitting?
I ask because I had to use a hydraulic press to get mine in, before I even tightened the nut. I can't imagine this thing popping out. In fact, I've had the charge pipe pop off a couple times until I updated to band-clamps. This thing is still in place.
Old Jul 29, 2016 | 05:25 AM
bugeye1031's Avatar
bugeye1031
Moderator
Mine went in easier than that....not sure why the difference. I wasn't watching at the time and wasn't logging. I'm running an AccessPort Stage 1 tune with Alta intercooler....upgraded the turbo to JCW specs when I had it rebuilt.
Old Aug 3, 2016 | 09:02 AM
Dr. Spade's Avatar
Dr. Spade
One could also buy a small pipe to replace the one that routes off to the noise maker as well no?
I definitely like your idea though.
As far as the hot side resonator I ended up replacing the whole tube after having a little pipe that wasn't rolled. So under high boost it would blow off.
Old Aug 3, 2016 | 09:21 AM
bugeye1031's Avatar
bugeye1031
Moderator
Decided to go the easy but expensive route - $81.80
https://www.ecstuning.com/ES2612079/
Old Aug 3, 2016 | 12:14 PM
Dr. Spade's Avatar
Dr. Spade
I assume that's the stock on on N18 motors
Old Aug 12, 2016 | 06:09 AM
bugeye1031's Avatar
bugeye1031
Moderator
Yes, that's correct. Installation was smooth....I'm not sure of the material, but it's not very flexible, but it isn't hard plastic. It came with new hose clamps.
Old Aug 12, 2016 | 06:20 AM
cguzz's Avatar
cguzz
I used this also to delete my noise maker. Got it from the dealer for about the same price.
Old Mar 26, 2018 | 04:26 PM
thesilkiest's Avatar
thesilkiest
Can you comment on what differences you felt \ noticed after this?
Old Jun 10, 2018 | 12:49 PM
MrGrumpy's Avatar
MrGrumpy
yes I’m interested in the results as well. I’m going to be replacing my turbo as soon as it gets delivered, I have the pre-Intercooler pipe in the way to delete the resonator. I have been looking for a good way to smooth out the air-flow from the other side of the Intercooler to the intake, but have been having trouble finding something that looks effective to me (low cost is a definite bonus)
Old Jun 10, 2018 | 12:55 PM
MrGrumpy's Avatar
MrGrumpy
As for deleting the noise-maker, can a guy just cut a piece of tubing and clamp it in place of the piece that diverts to the noise-maker (like on the other one)? I honestly have no clue if this is possible or not, but seems like it would be a quick and cheap way to go, as opposed to spending $105 which is what that pipe is selling for now. I found another replacement option that costs $230+, and honestly, it looks like a piece of anodized aluminum tubing clamped between two hoses!
Old Jun 11, 2018 | 01:39 AM
drea-min's Avatar
drea-min
Noise delete
Originally Posted by MartinR56
Guys,
2" OD aluminum pipe
Before and after!
+1
Did exactly the same why pay expensive hoses when you can invent the same purpose... Only the looks. Right on!
Old Apr 3, 2019 | 03:15 PM
SNOOPYS_MINI's Avatar
SNOOPYS_MINI
Bump, because never answered..... lol
Old Apr 8, 2019 | 04:33 PM
SNOOPYS_MINI
So I’ll answer myself...lol
2-1/4” pipe. 2-1/8” would be a touch better, but near impossible to find in a short length.
Old Apr 8, 2019 | 04:45 PM
I like mini clubman's's Avatar
This is exactly what I did a couple days ago. After replacing my starter and walnut blasting the valves I deleted the noise maker with 2 1/4" exhaust pipe. Very tight at the one elbow but hasn't popped off yet under some spirited short blasts.
Old Oct 3, 2019 | 06:55 PM
mini-is-for-me's Avatar
mini-is-for-me
It seems like you could leave a piece of the hose going to the noise maker, insert on of these and then put a hose clamp on the tubing as well which would be solid.
https://www.amazon.com/SEACHOICE-Twist-Turn-1-25-Inch-Marine-Neoprene/dp/B002IZHF08/ref=sr_1_47?keywords=1+1%2F4+rubber+plug&qid=1570153772&sr=8-47 https://www.amazon.com/SEACHOICE-Twist-Turn-1-25-Inch-Marine-Neoprene/dp/B002IZHF08/ref=sr_1_47?keywords=1+1%2F4+rubber+plug&qid=1570153772&sr=8-47
Old Nov 16, 2022 | 05:04 PM
Jeffrey Daitz's Avatar
Jeffrey Daitz
Noise Maker Delete
This is interesting. Could be beefed up a bit, but I like the simplicity.
Old Dec 16, 2022 | 02:59 PM
Jeffrey Daitz
I actually made the same insert as the YouTube video. You don’t have to cut anything. Plug and play! For fun (and backup I guess) I capped off the end with a nice heat rated silicone cap. The car sounds more organic now. My mechanic might check the boost level for me. Pulls about the same.
DivineXtacy
Oct 1, 2016 04:24 PM
JayR50
Cooper (non S)
15
Feb 25, 2016 08:39 AM
Jan 14, 2016 02:26 PM
Jan 12, 2016 12:53 PM
