F55/F56 NM Springs with Standard Suspension
Old Jan 13, 2016 | 10:26 AM
DunkM's Avatar
DunkM
So sort of day dreaming here, because I am not going to be able to even consider mods to MINI until Summer time. but I was wondering if anyone put the NM springs on a MINI with the standard suspension and how it handled (and looked) after that.
I was originally planning to go the JCW coilover route, but realized that is a lot of money to simply lower a car, as I want to keep the suspension as close to standard suspension comfort as possible.
It just seems that I could get the NM springs, JB tuning module, and the NM rear bar, plus make my car payment that month for less than the cost of the coilovers... To make matters worse, I live 25 minutes from Way Motor Works.
What does the hive mind collective have to say?
Old Jan 13, 2016 | 01:55 PM
MarcoPolo's Avatar
MarcoPolo
the ride with the NM springs will be rougher and you will bottom out more often. all depend on how your roads are. if roads are smooth then you got nothing to worry about.
the NM Sway and Burger tune will make you smile.
if you really want coils, KW V1's will do the job just as much. i may be wrong...thought they were cheaper? correct me if i am.
Old Jan 13, 2016 | 02:30 PM
KW here :
https://www.ecstuning.com/Mini-2014-...ion/Coilovers/
without / with EDC they are $ 1589.99 and you get 100 ecs gift card with purchase.
Old Jan 13, 2016 | 03:18 PM
TheBigNewt's Avatar
TheBigNewt
If what you want is for the car to corner better, less body roll, less understeer and don't need the car lowered just get a thicker rear antisway bar from Way. They did mine on my 2007 MCS for $300 and I loved it. I think the F56 is pretty "floaty" standard. I'd for sure add a sway bar. The car rides the same but corners better.
Old Jan 13, 2016 | 04:30 PM
DunkM's Avatar
DunkM
Beginning to think Springs and sways are the way to go.
Old Jan 13, 2016 | 10:14 PM
honderpilot's Avatar
honderpilot
I have this set up. Lmk if you have any questions
Old Jan 14, 2016 | 07:40 PM
DunkM's Avatar
DunkM
Our roads are pretty smooth, but we suffer from two major offenders. Short tall speed bumps, and those metal plates used to cover up holes, how does it handle that, does it crash over them or is it firm but composed.
Secondly, does it feel under damped, so if you were to push down on the car near a front wheel and then let go, does it just seem to oscillate a little too much.
What kind of driving do you do?
How would you rate it in harshness and handling, from a 1-10 using the stock as a 5.
Old Jan 14, 2016 | 11:25 PM
honderpilot
We have bad roads here with raised manholes, speed bumps, railroad tracks... Basically lowering hell. I'd say it is firm and composed.
There are no unusual oscillations like you see on YouTube of a Honda Civic with cut springs. It is not noticeably different from stock, if anything it's stiffer.
I do lots of city and highway driving. Around town it is stiffer going over man holes and whatnot. Avoid major potholes or else you'll feel bad for your car. Other than that you'll be fine. It's smooth as butter on the highway and extremely live-able. Driving spiritedly, it feels like you're always in sport mode when you're in middle mode and sport mode feels even more responsive. It's very tight handling and like I said, watch out for curbs or anything crazy and you'll be fine.
Id say the stiffness is a 7.5/10. If you drive conservatively it's about a 7 and if you're aggressive it can feel like an 8 if that makes any sense. I'm usually more on the 8 side but when I want a relaxing cruise and the roads are average, it's rides like stock (except with less wheel gap).
Excuse any typos, lmk if you have any more questions
Old Jan 23, 2016 | 09:23 AM
MidnightF56's Avatar
MidnightF56
I find the JCW Pro suspension to be more comfortable due to the better damping, even though the springs are stiffer. It's my favorite mod, tied with getting the Pilot Super Sports, even though it was the most expensive. No regrets.
My problem with the standard suspension wasn't the spring stiffness, it was the shitty damping and rebound.
Old Jan 23, 2016 | 12:34 PM
vetsvette's Avatar
vetsvette
Moderator
I'm happy with my sport suspension for the moment. JCW Pro system will be going on later this year. I'll have a sport system for sale at that time.
Old Jan 24, 2016 | 01:59 PM
honderpilot
How is it adjustable? How does that work?
Old Jan 24, 2016 | 04:52 PM
DunkM's Avatar
DunkM
The JCW Pro system is simply a height adjustable system, it does not have damping adjustability. It seems to me that the people really like it because it was designed based on MINIs wants and not an aftermarket tuning company. (MINI most likely chose something with better damping and lower spring rates than aftermarket companies) I have not ridden a F56 with them on so I cannot say these things for sure. (Also see the fact that they have factory warranty). I also agree that they are awesome and would be my go to coilover.
Regarding the springs, I totally agree that the stock shocks are slightly underdamped, which was the real reason I started this post, worrying that the NM springs were going to have a too high a spring rate and destroy the shocks. But I am feeling pretty confident now since my dealer now sells them.
Old Jan 25, 2016 | 07:56 AM
With the adjustment tool like a coilover kit. Nuts that adjust on the tube with a special wrench in the kit. You can see it on the bottom of the red spring, what it sets on.
https://www.northamericanmotoring.co...-prices-2.html
Old Jan 25, 2016 | 01:39 PM
honderpilot
Do you have to take the wheels off the car every time you wanna adjust it?
Old Jan 25, 2016 | 01:49 PM
Its a tight fit when down all the way. Most people jack the car up if they cant reach , then with the widen gap adjust a little ( if you have bigger wheels this will be harder ), then drop it back down slowly. Drive down the road to set in. Then adjust again if needed. Count your turns and make note you match the other side the same. Rears you can get from the back underside some. As the coil is separate.
More info here
https://www.northamericanmotoring.co...-unboxing.html
Emnotek
Jan 13, 2016 11:49 AM
Wisconsincooper10
Jan 4, 2016 02:51 AM
kfmuller
Dec 22, 2015 08:41 AM
Mini_Touge
Suspension
Dec 3, 2015 11:45 AM
SmurfNinja
11
Nov 25, 2015 01:20 PM
