R56 R56 P0300 codes
Old Jan 8, 2016 | 09:00 AM
zrover's Avatar
zrover
R56 P0300 codes
I have an 09 MCS. I have codes reading all cylinders are misfiring. I have changed all coil packs and all spark plugs. Still misfires and throws same codes. Runs terrible at startup and then starts to come back to life after a bit. Sometimes it will not have full power, so I turn it off and start it back up then I have power back. Any ideas?
Thank you!
Old Jan 8, 2016 | 09:46 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
How many miles are on your R56? Curious as just about every 50,000 miles the intake valves need to be cleaned to maintain optimum engine performance. Once the build-up reaches the maximum tolerable level, the engine will begin to run rough and misfire. You may have a rough idle, poor acceleration, stalling or single to multiple cylinder misfires. If you have any of these symptoms, check for valve residue build-up.
What to look out for (from our carbon cleaning DIY). I'd start here and see what you find.
888.280.7799 | 6am - 5pm PST
Old Jan 8, 2016 | 09:49 AM
zrover's Avatar
zrover
I have 155,000 miles on it. I bought it with 40 and have not cleaned it. So you are saying i need to clean out the carbon?
Thank you
Old Jan 8, 2016 | 09:52 AM
PelicanParts.com
Vendor
Thank you
If it hasn't been done yet, absolutely. Inspect your valves. We have a great DIY that can help you do this yourself if you feel capable. In the years past a walnut blaster has been used to clean engine valves with the cylinder head still installed. This is still the best and fastest method to clean the valves. However, many DIY mechanics may not have this tool. So in our article we show you how we were cleaning MINI valves before MINI and BMW released the walnut blaster adapter for these engines.
Old Jan 8, 2016 | 11:21 AM
kemalo2002's Avatar
kemalo2002
Thank you!
Might be a bit of a leap but mine had the exact symptoms. I did the intake cleaning and had the fuel injectors cleaned which didn't help. Eventually it turned out to be the high pressure fuel pump.
Old Jan 8, 2016 | 11:26 AM
PelicanParts.com
Vendor
Yes, this is another idea I had as I ran across a few threads that pointed to the HPFP, but the carbon clean up should still be done to help rule it out of the equation. (NAM thread for reference HERE).
Old Jan 8, 2016 | 04:57 PM
zrover's Avatar
zrover
Thank you all for your input. To clean the valves how do I do it and where can I get a walnut blaster?
Old Jan 8, 2016 | 04:58 PM
zrover's Avatar
zrover
Also where is the high pressure fuel pump located?
Old Jan 8, 2016 | 05:13 PM
zrover's Avatar
zrover
What aboutt a sand blaster. I have one will it work?
Old Jan 11, 2016 | 11:56 AM
PelicanParts.com
Vendor
The carbon clean up info is HERE. The article will give you a step by step process on how to do with without having to buy the walnut blasting tool and other tools. If you do wish to walnut instead, the tool is here and the wand is below it. There is a DIY here and the other items you'll need for the job.
The pump is mounted to the left side of the cylinder head (red arrow) and is driven by the intake camshaft. (Photo is from our HPFP DIY replacement)
Old Jan 11, 2016 | 12:42 PM
Helix13mini's Avatar
Helix13mini
No the sand will damage the metal. The idea with the walnut blasters is that the media is softer than metal, but will still remove carbon build-up.
Old Jan 11, 2016 | 01:48 PM
nkfry's Avatar
nkfry
Thank you!
Find a quality scan tool read all the codes being provided, there may be more to the story.
Could need any of the below work performed:
Carbon blast
Compression test & leak down test
HPFP replaced
Could also be a thermostat issue
Timing chain
You need to find a qualified indy shop to diagnose the issue further and not keep throwing money at it.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jan 21, 2016 | 10:15 PM
zrover's Avatar
zrover
I changed the high pressure fuel pump and now it runs great!!
Thanks for all of your help!
Old Jan 22, 2016 | 08:33 AM
PelicanParts.com
Vendor
Great! Glad your issue is resolved. Be sure to get that carbon clean up soon.
Old Jan 22, 2016 | 08:34 AM
zrover's Avatar
zrover
Thanks....I did that too.
Old Jan 22, 2016 | 10:54 AM
Get this for the future, will read all the codes.
Some code readers will not find all the stored codes if there is a check engine light.
Ours does:
Glad it was just the HPFP, https://www.northamericanmotoring.co...ese-codes.html
Professional BMW/MINI Scan Tool
https://www.ecstuning.com/Search/SiteSearch/ES2975699/
tommybwell
Jan 6, 2016 06:49 AM
dhessel
Jan 5, 2016 10:58 AM
grussell
R55 :: Clubman Talk (2008+)
Jan 5, 2016 08:53 AM
HorizonBLueN18
Jan 5, 2016 02:47 AM
Mab01uk
Classic Mini Talk
Jan 4, 2016 10:24 AM
