Electrical Swapping out horns.
Old Nov 29, 2015 | 10:29 AM
Rune's Avatar
Rune
Swapping out horns.
Since my car is at least 12 years old, something electrical was bound to fail. Sure enough, my horns died a couple months ago, and I was dreading not having that fallback.. After reading a bunch of threads, I settled on the
FIAMM Freeway Blasters FIAMM Freeway Blasters
, both 72112 and 72102 (High and Low Tone). They look identical to the MINI horns, except that they're made in the USA.
Here's the package. It's identical to the factory. The connector on the left is from the dead horn that I pried off.
Here's another closer picture.
Using a dremel, I cut off the surrounds.
A lot of people end up soldering or flattening this bit to fit to the horns.. However, they are a snug/press fit! No need to splice anything with the horn layout. Here's the completed horn. All that's left is to reconnect it to the stock wiring harness and off you go!
Old Nov 29, 2015 | 02:15 PM
Capt_bj's Avatar
Capt_bj
I just spin off the connector and expose the two wires (a hot and a ground), crimp on simple connectors and plug the wires to the horns. Easy! A little heat shrink or paint on insulation helps keep everything water tight.
Now if you want some serious horns, this is what I put in my 79
Old Nov 30, 2015 | 08:59 AM
808keith's Avatar
808keith
Nice write up. I replaced mine with Hella supertones sharp tones.
Old Dec 3, 2015 | 11:16 AM
Yep some go sharp tones or Accessory Horn Kit
https://www.northamericanmotoring.co...arp-tones.html
Or all the way , "get out of my way " air horns.
Old Dec 3, 2015 | 02:37 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Would love to see a video of you honking the horn(s) in your Mini with those bad boys.
888.280.7799 | 6am - 5pm PST
Mega Babies
Tires, Wheels, & Brakes
15
Jul 13, 2018 03:49 AM
AngeloCarrion
12
Nov 8, 2015 02:35 AM
RR|Suki
Nov 5, 2015 04:19 PM
buddabounce
Nov 3, 2015 05:47 AM
