Electrical heated mirror / puddle light upgrade.
Old Dec 5, 2015 | 08:38 PM
gpwpat's Avatar
gpwpat
Is it possible to retrofit 2003 to heated mirror and puddle lights? Maybe a working harness from a later car? I don't need heated seats here in Ca. But the fog builds up on the mirrors here. I need rear fogs programmed and heated mirrors would be useful.
Old Dec 6, 2015 | 01:37 AM
Eric_Rowland's Avatar
Eric_Rowland
Might want to check and see if you have 5 wires vs. 3 on the body side mirror connector. They would both be black. If you do, you'd only need the mirror side w/wires and terminations on the mirror. Can't see MINI making an entirely different harness just for heated mirrors.
Puddle lights can be added - there's an OEM option, IIRC. But it's not plug and play. You've got to drill holes and run wiring.
Old Dec 6, 2015 | 10:05 PM
Rune's Avatar
Rune
I just did a puddle light upgrade on my 05/2003 R53 Cooper S.. No need to drill anything, just cut some rubber grommets. Did both doors! Looks great.
https://www.northamericanmotoring.co...r-the-r53.html
Can't help you with the heated mirrors, I think that needs a different electronical control system.
Old Dec 7, 2015 | 05:30 AM
chris.j.lamb's Avatar
chris.j.lamb
Heated mirrors is easy, just feed them off a switched feed, no fancy controller.
Buy a heated mirror, swap with unheated, run ground to door metal.
Then run feed through existing car to door route, get switched feed from fusebox in footwell.
Simples.........
shahriar35
Jan 5, 2016 04:27 PM
RicWRX
Dec 17, 2015 08:38 AM
jideonu86
Nov 16, 2015 07:28 AM
ALLMAGAutoParts
Nov 16, 2015 06:05 AM
coogamoogakid
Nov 9, 2015 02:36 PM
