R56 Limp mode B2AAA And P0128
Old Oct 20, 2015 | 03:22 AM
ahmedalsurmi's Avatar
ahmedalsurmi
Hello
i cant get out limp mode
i have this codes
P0128
B2AAA
and recently i have replaced thermostat before 3 weeks with new one
how to fix it
Old Oct 20, 2015 | 10:24 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
P0128 in the Bentley Manual is Coolant thermostat (Coolant Temperature Below Thermostat Regulating Temperature) and Program map thermostat: Sticking in open position. It could be the thermostat or the CTS (Coolant temp sensor 13-62-7-535-068), which is located in the thermostat housing. May not be your issue though and could be the thermostat. What thermostat did you install?
888.280.7799 | 6am - 5pm PST
Old Oct 24, 2015 | 06:21 AM
ahmedalsurmi
i have replaced the Thermostat from BMW Service with the same number part
why it will the CTS Or Thermostat housing
they are Brand NEW
Old Oct 24, 2015 | 06:22 AM
ahmedalsurmi
Whats Wrong ?
Old Oct 26, 2015 | 09:23 AM
PelicanParts.com
Vendor
So you had a BMW dealer replace the thermostat? Or did you replace it yourself?
Old Oct 27, 2015 | 04:33 AM
ahmedalsurmi
i replaced it my self
Old Oct 27, 2015 | 08:42 AM
PelicanParts.com
Vendor
This NAM thread here had the code P0128 and had to replace the thermostat. I can't seem to find much on B2AAA unfortunately. So I am unsure if and how the two codes may be related. Since you did the install yourself, I would go back over everything and make sure you didn't leave something disconnected. Figure 7 and 8 HERE show some sensors you disconnect to change it so check over those and everything else. Just to be sure.
Old Oct 29, 2015 | 05:08 AM
ahmedalsurmi
thanks for replay
the sensors are connected in image 7 and 8
http://www.pelicanparts.com/techarti..._med/pic12.jpg
but i think that i mixed the hoses which one on the left and right which
if i mixed the hoses will i get this
the hoses come from dash to the thermostat
Tuckermon1
Jun 19, 2017 08:41 AM
papawhiskey
Dec 14, 2015 01:10 PM
Blacked Out 2010
R57 :: Cabrio Talk (2009+)
Oct 29, 2015 06:00 AM
slide mini
Oct 19, 2015 06:37 PM
gfletch
Oct 18, 2015 01:11 PM
