loud engine ticking problems/rough idle
Old Aug 23, 2015 | 11:18 AM
Marco Guardado's Avatar
Marco Guardado
hello I have a 2007 Mini Cooper base model & 4 moths after purchasing(used) the vaccum pump starting making a really loud no king sound at idle and car idle goes crazzy low and wants to turn off , I've had the vacuum pump replaced and still the same problem . This only happens when the motor is past 95 degrees celcius . When car accelerates past 1,500 rpm all noises problems go away and car is back to rough idle /nocking noises when I ce to a stop again. Anny suggestions/help before I dump lots of $$$ into a mechanic?? 3 mechanics have already checked it and found nothing that could be causing this , there is no engine codes. Thanks in advance
Old Aug 23, 2015 | 08:27 PM
AZdsrt's Avatar
AZdsrt
Call your Mini dealer and see if you qualify for timing chain replacement 'campaign'..
Old Aug 25, 2015 | 07:47 PM
Systemlord's Avatar
Systemlord
Yeah definitely sounds like a timing chain gone bad! There's a huge thread about this problem, very common issue. Do not run you engine anymore because if the timing chain comes off your problems will multiply!
Been there, heard it, replace timing chain components and then less than two years later had to replace the timing chain tensioner that was installed new with the new timing chain.
Old Sep 1, 2015 | 07:42 PM
hooverr77's Avatar
hooverr77
Thank you for the help.
Old Sep 14, 2015 | 06:53 PM
Marco Guardado
My timing chain is fine , the noise comes from the driver side of the engine From the Break Vacumm pump!
Old Sep 14, 2015 | 06:54 PM
Marco Guardado
No noises from Timing Chain , Noise only From Vacumm pump ! on the driver side.
Old Sep 14, 2015 | 06:55 PM
AZdsrt's Avatar
AZdsrt
At least it's cheaper to repair. However, don't drive it until it's replaced.
Old Sep 15, 2015 | 01:22 AM
Systemlord's Avatar
Systemlord
You're not going to get any codes as there's no electrical connection or anything monitoring the mechanical vacuum pump, I promise you if the vacuum pump seizes up it will also seizes up your exhaust camshaft causing it to shatter causing engine damage! Valves will strike the pistons, you get the idea. This has happened to other's before and they had no clicking noises to warn them of impending damage.
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
makg
Aug 21, 2015 02:49 AM
damncajun
Aug 17, 2015 08:25 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
Lt. Dan
Aug 10, 2015 08:23 AM
