Suspension KW V3's Installed Today
Old Jul 9, 2015 | 10:36 PM
wzabrouski's Avatar
wzabrouski
Handles great!
Old Jul 11, 2015 | 04:16 AM
CPap's Avatar
CPap
Looks good. How do the they compare to your previous setup? I have the nm/billies as well and was thinking of going to the kw's.
Old Jul 11, 2015 | 04:34 AM
Indimanic's Avatar
Indimanic
Any idea what the spring rates are for the 3's?
Old Jul 24, 2015 | 08:36 PM
VariableR58's Avatar
VariableR58
Like It!
Old Jul 25, 2015 | 11:20 AM
wzabrouski's Avatar
wzabrouski
They handle completely different. So much better. It is a different ride when you have springs paired with shocks. Night and day compared to the NM/Bilsteins but then again the price difference is huge also.
Photo from when I had them corner balanced and aligned.
Old Jul 25, 2015 | 10:00 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
the KWs ride so much better than the lowering springs and Bilsteins. Main reason is due to shock travel. Getting the rebound in the rear set is softer than normal due to the valving they use, but I've installed a few sets now and got them working well now.
We are now using more KW V2s as most don't need the extra adjustment of the V3s and they are a little more cost effective.
http://www.waymotorworks.com/kw-vari...ountryman.html
Old Nov 12, 2015 | 09:13 PM
countryman-s's Avatar
countryman-s
Does lowering your countryman not mess up your auto leveling system on the HID headlights?
Old Nov 13, 2015 | 07:26 PM
WayMotorWorks
Vendor
Often you need to readjust the headlights, but the sensors are still in place to make them still adj on their.
Old Nov 15, 2015 | 09:47 PM
3leafz's Avatar
3leafz
Is it currently set on 1" drop? I would love to get one set for my CM JCW.
Old Dec 3, 2015 | 06:30 AM
teinesina's Avatar
teinesina
I'm so glad to see this thread pop up! I had the kw v3s installed a couple months ago and it was really hard to find anyone else running them. I've been playing around with the settings and I'm trying to find a good combination of ride and no bounce. The total drop is 2 1/2 inches in front and 2 in rear. That's as much as they can do with my 18 inch wheels . I started out with the settings rebound and compression both where they came set which I think was 5. I now have the rebound all the way down to one click above full hard. Drove like that for a bit. Then i turned the compression all the way down to one above hard for a bit. Then I brought the compression up one soft on just the rear yesterday. Feels pretty good. There's definitely some bounce but it's kind of worth it. And I'm loving it! I wish the rear rebound could be adjusted without taking the whole thing off. What settings are you guys using?
Old Dec 3, 2015 | 08:48 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Very nice choice! How's the ride comfort/feel compared to stock? Especially when it comes to bumpy roads and small pot holes?
888.280.7799 | 6am - 5pm PST
Old Dec 4, 2015 | 06:15 AM
teinesina's Avatar
teinesina
They absorb high speed bumps/holes pretty well but you definitely feel it. At slow speed you really feel the bounce. But when you hit a corner hard it just hunkers down and flies low. It is the most amazing feeling!
Body roll is non-existent now. but I also have it on basically the stiffest setting possible. One click above full hard. I didn't get them on in time to test at autox before the season was over so now I just have to wait......all...winter
I was on NM springs with stock shocks before.
Old Dec 4, 2015 | 07:52 AM
PelicanParts.com
Vendor
Very nice! That's alright, at least you'll get some ideas of what settings feel good and then you can really dial it in once you get out on the autox course. Be sure to report back on how they do! I'm looking into the V3's possibly or the Clubsports ($$$).
Old Dec 20, 2015 | 02:47 PM
wzabrouski's Avatar
wzabrouski
Bump is 4 from full hard. Rebound is 9 clicks open in the rear and 7 in the front.
adrchn
Aug 13, 2019 02:11 AM
bneer
Jul 15, 2019 04:41 PM
squawSkiBum
Oct 2, 2015 09:21 AM
SunnySideUp
11
Aug 26, 2015 06:42 AM
