4 lugs? 5 lugs? Flip a coin or what?
Old May 21, 2015 | 12:37 PM
MiniPhoto's Avatar
MiniPhoto
I've got a 2014 Mini Cooper Convertible, and unfortunately we hit a pothole in Houston and I believe I now have two bent rims... inside of 1400 miles mind you.
Currently I have the black 17" Sport Conical factory rims, which I know I wont want to replace at the cost of factory parts.
So I've been researching online and most things that I find say that its a 5x112 or 5x114.3 pattern..... except I only have 4 lugs on my rims. So is it a 4x100?
Old May 21, 2015 | 12:44 PM
2014 R57 MINI Cooper Convertible 4x100 56.1 CB
Here is the NON S Cooper Convertible options.
http://www.ecstuning.com/Mini-2014-Cooper-R57-Base-Convertible-L4_1.6L_N16B16A/Wheels/OEM_Alloys/
aftermarket:
http://www.ecstuning.com/Mini-2014-Cooper-R57-Base-Convertible-L4_1.6L_N16B16A/Wheels/Aftermarket_Alloys/
The 2014+ F56 has the 5x112 wheels 66.6 CB
Old May 21, 2015 | 01:06 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
You might have luck doing a Google search for a shop that does wheel restoration. Most of the time they can fix bent wheels, depending on how bad they are. Found Houston Wheel Repair. Check it out and see what they might be able to do before you have to buy 4 new wheels. Good luck!
-Luccia
888.280.7799 | 6am - 5pm PST
Old May 21, 2015 | 03:07 PM
MiniPhoto's Avatar
MiniPhoto
-Luccia
Well..... secretly I do actuall want some aftermarket rims. I like a classic 5 spoke rim. So shhhhhh! Dont tell my partner that they can restore rims.
Old May 21, 2015 | 03:20 PM
PelicanParts.com
Vendor
Your secret is safe with me.
-Luccia
Old May 21, 2015 | 03:22 PM
MiniPhoto's Avatar
MiniPhoto
I'm liking the XXR 535's.
Old May 21, 2015 | 03:30 PM
MiniPhoto's Avatar
MiniPhoto
Yeah... I think those XXR 535's (as seen here) would look good on my metallic white silver Union Jack convertible.
Old May 21, 2015 | 04:17 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Sorry to hear about your wheel damage
You can also save your receipts and put in a claim to the city govt for not maintaining the roads causing damage to your wheels/tires.
Old May 21, 2015 | 05:51 PM
MiniPhoto's Avatar
MiniPhoto
Here's the damage. I didn't want to believe it, but I finally found it.
Am I the only one with this kind of luck? Not even 1500 miles on it yet.
Attached Thumbnails 4 lugs? 5 lugs? Flip a coin or what?-20150521_191251.jpg
Old May 22, 2015 | 05:14 AM
Ouch, that stinks.
Some repair places will do it if the wheel is not cracked. But if the repair cost more then a new wheel then you have the wheels linked above.
Old May 22, 2015 | 05:38 AM
MiniPhoto's Avatar
MiniPhoto
With +20 offset, will these fit the factory ContiContact Pro tires, and will they stick out any?
http://www.nlmotoring.com/XXR-535-Wh.../53578082n.htm
And if the 17" factory wheels that I have now, are 17x7 should I go with these instead?
http://www.nlmotoring.com/XXR-535-Wh.../53577082n.htm
These have +35 offset, so will they stick out even further?
Old May 22, 2015 | 08:42 AM
MINIAC's Avatar
MINIAC
The lower the offset the further they will stick out. ET20 is not an appropriate offset.
Old May 22, 2015 | 12:29 PM
MiniPhoto's Avatar
MiniPhoto
So the 17x7 with +35mm is the way to go then....
Old May 22, 2015 | 12:33 PM
Have you looked at the NM Engineering wheels , they are pretty nice if you go aftermarket and light weight for the size.
Old May 27, 2015 | 10:01 AM
MiniPhoto's Avatar
MiniPhoto
The good news is that my suspension has been checked out and it is completely fine and non-damaged. The rubbing during a hard left turn is from the bent rim.
The bad news is that I have two bent rims. My options are to pay $575 for factory replacements from ECS, $806 for factory replacements from the dealership and beg them for a tire/wheel warranty, or $460 for aftermarket XXR 535's.
My only question is will the 17x7 XXR 535's fit the factory run flat tires?
Old May 27, 2015 | 10:32 AM
MINIAC's Avatar
MINIAC
I doubt that aftermarket wheels are designed with the EH2 hump profile recommended for run flat tires. The two humps on the wheel bead profile keep the tire from slipping off the wheel in the case of air pressure loss.
Old May 27, 2015 | 11:47 AM
Dont like the NM wheels ? Nice light weight vs OEM .
Old May 27, 2015 | 12:50 PM
MiniPhoto's Avatar
MiniPhoto
I like the one you have pictured above, but it appears that they only have it in 18". I'm sticking with 17" because my tires are still good. They've only got 1500 miles on them.
Old May 27, 2015 | 01:20 PM
Just the 18" from NM for now.
Old May 28, 2015 | 01:51 PM
kyoo's Avatar
kyoo
just to reaffirm, all the hardtop/coupes are 4x100, just the bigger ones that go up in size
Old May 28, 2015 | 01:59 PM
4x100 for the R50 R52 R53 Gen 1 (2002- 2008)
4x100 for the R56 R55 R57 R58 R59 Gen 2 (2007+)
5x120 for the R60 Countryman & R61 Paceman
5x112 for the F56 F55 Gen 3 (2014+)
freckles81
Jan 15, 2017 06:33 AM
theblackfalcon
Oct 19, 2015 05:22 AM
Giants9595
Sep 29, 2015 10:49 PM
Sep 18, 2015 12:45 PM
papawhiskey
Sep 14, 2015 05:47 PM
