R56 40F coolant temp fluctuation...normal?
Old Apr 9, 2015 | 11:45 AM
wsalopek's Avatar
wsalopek
2009 R56 MC...
My coolant temp, via Torque / OBD II, fluctuates from about 180F to 220F randomly as I drive down the interstate at a constant speed (75-80...New Mexico)...A/C on or off doesn't seem to matter...throttle position doesn't seem to matter...outside temp doesn't seem to matter.
I'm trying to get a feel for the interval...but right now it seems random...every couple/few minutes is a basic guess...it'll stay at 220-ish for a couple/few minutes, drop down to 175 to 185 within maybe 30 seconds, and then come back up.
Is that kind of fluctuation normal?
Thanks guys...
Bill
Old Apr 9, 2015 | 06:47 PM
pokeyjoe's Avatar
pokeyjoe
Veteran: Navy
Sounds like the thermostat is sticking.
Old Apr 10, 2015 | 05:27 AM
v10climber's Avatar
v10climber
Yeah that does sound like something weird going on with the thermostat. Once my car gets up to temp (220-ish) it'll stay there unless I'm sitting at a stoplight or something and then it will drop a bit. But just regular cruising it should stay a pretty consistent temperature.
Old Apr 10, 2015 | 07:12 AM
rckrzy1's Avatar
rckrzy1
well when putting a heavy load on and or sport mode mine drops from 220 to 185 every day , very normal.
Old Apr 10, 2015 | 10:26 AM
richardsperry's Avatar
richardsperry
It is not normal. It should only drop if you have the AC on max, or are really putting the spurs to it.
Mine just hangs out at 220. down to 218, up to 222, mostly at 220. Max AC it drops like a stone to 175 or so. Hit the boost for more than 5 seconds, and it drops.
Old Jun 11, 2022 | 07:21 AM
ShawnTitus3's Avatar
ShawnTitus3
Any update on this? Mine does the same thing it goes from 220 to 250 then drops to 189 then stays at 220 for a few minutes then does it again and I’ve bled the system idk what’s wrong with it
Old Jul 17, 2022 | 08:31 PM
Lakotamani's Avatar
Lakotamani
Mine did this today, bump for answers
Old Jul 18, 2022 | 12:24 PM
If their is air in the system it will jump around (but that is if their is a leak or you diod not fill it up all the way after a thermostat change) but what causes it to jump the most of the sport button and in air conditioning more. If its super hot outside the high fans will kick on and the thermostat will open more.
" Mine just hangs out at 220. down to 218, up to 222, mostly at 220. Max AC it drops like a stone to 175 or so. Hit the boost for more than 5 seconds, and it drops." My JCW N14 does this also and get a little hotter at times.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
PsychoRallye
21
Feb 17, 2019 06:08 AM
vulkandino
Oct 31, 2015 08:29 PM
navybsn
Oct 4, 2015 03:27 PM
point665
Sep 29, 2015 12:41 PM
