r56 valve cover bolt torque?
Old Mar 7, 2015 | 12:10 PM
dhoss32's Avatar
dhoss32
i read on here to torque to 9lbs. when i got to 7 lbs the bolt broke. i know the torque is not critical but wanna get it right so i dont have to keep checking and tightening little by little. also, i was lucky enough to just take the cover off and remove the broke bolt by hand. that could have been a horror show.
Old Mar 7, 2015 | 03:11 PM
SPRINTCARS's Avatar
SPRINTCARS
Although there is a torque spec. It's more important to do it in a criss cross pattern. I just run them down gently snug going back and forth til it sits flats. Then gently snug. Your only flattening an o-ring then it hits the hard plastic cover to the head. Then just a snug. I've never had an issue.
Old Mar 7, 2015 | 05:26 PM
afadeev's Avatar
afadeev
Just checked Bentley: 10 Nm or 7.3 ft-lbs.
You have to be very careful with those low torque values, and use a dedicated in-lbs torque meter. I've used the following with perfect outcomes, but I'm sure there are other (cheaper) options out there:
https://store.snapon.com/Standard-Mo...--P642513.aspx
a
Old Mar 8, 2015 | 11:11 AM
dhoss32's Avatar
dhoss32
thanks for the help
Old Dec 28, 2019 | 10:11 AM
SNOOPYS_MINI's Avatar
SNOOPYS_MINI
Just changed this gasket, thanks for the torque specs.
Old Dec 28, 2019 | 01:28 PM
giorgos's Avatar
giorgos
Tightening sequence according to newtis:
https://www.newtis.info/tisv2/obj/FWA9zb4
Old Dec 29, 2019 | 06:09 AM
SNOOPYS_MINI
Saw this a day late. I did the typical criss cross from center out. :(
Old Dec 29, 2019 | 06:26 AM
giorgos's Avatar
giorgos
One could argue that I posted the link to newtis one day late. :-)
You should be fine if you cleaned the surfaces well, checked that the gasket is correctly fitted and did not tighten the bolts to full torque in one go each.
Old Dec 29, 2019 | 09:57 AM
SNOOPYS_MINI
Cleaned everything well, tightened in steps.
Dave_07
Nov 20, 2019 09:54 AM
mini907
Apr 7, 2019 06:29 AM
Tinythumb
Sep 29, 2012 11:29 AM
Motorrr
Tires, Wheels, & Brakes
May 4, 2007 05:30 PM
spillman
Dec 19, 2005 08:20 AM
