R56 Valve Cover Torque
Old Aug 18, 2011 | 08:50 AM
Dave_07's Avatar
Dave_07
Valve Cover Torque
I'd really appreciate it if someone could post the torque spec for the R56 valve cover. I searched the forum and didn't find it anywhere.
Dave
Old Aug 18, 2011 | 09:02 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Just snug them all down, valve cover bolts aren't critical for torque.
Old Aug 18, 2011 | 09:10 AM
Dave_07's Avatar
Dave_07
Thanks WMW. I can work with that.
Dave
Old Aug 18, 2011 | 10:20 AM
OPC's Avatar
OPC
RATTUS Deserticus
Torque spec depends on the size of the fastener. For the R53 M6 sized bolts, the Bentley manual called out 9ft-lbs. Pretty much just snug as Way wrote.
Old Aug 20, 2011 | 11:22 AM
Dave_07's Avatar
Dave_07
Thanks OPC. The new valve cover is in and "snug". The plastic cover contains metal inserts which "bottom out" as soon as they snug up to the mating head surface - so the metal bolt contacts the metal insert contacts the metal cylinder head. After that, snug is good, say 9 ft-lbs.
No leaks so far, but it is too soon to tell if this was a fix for the 2qts of oil lost in 6500 miles. I took the old valve cover apart and can't ID a problem. What I do know is that the #1 spark plug hole had about 1" of oil in it. Also, the outer peripheral area was leaking in a few areas but (IMO), not nearly enough to account for 2 qts and not a drop on the garage floor. I keep looking at the coolant for signs of oil - not there.
I don't really want to make a career out of this repair, just wish it all added up, and I could help out others with similar symptoms. With 65k miles, the life on this Just-a-Cooper has been uneventful up to now. After removing the valve cover, I noticed that the rubber gasket was brittle, which is somewhat to be expected, although I'd prefer not to change gaskets every 50k miles or so. I'm remembering back to when we had the recall performed where they replaced the blown fuse controlling the cooling fan. I asked "you sure this doesn't cause other problems?" "Not to worry" was their reply. I'm not saying, I'm just saying. Hopefully the new gasket and valve cover (and fuse) will prevent a future leak.
Dave
Old Mar 24, 2014 | 10:13 AM
biggripper's Avatar
biggripper
So the Bentley manual says to apply a thin layer "anti-friction compound such as glycerine" to the cylinder head contact surfaces. Has anyone done this? Is it completely necessary? What exactly is anti-friction compound?
Old Nov 20, 2019 | 09:54 AM
Bill Banche's Avatar
Bill Banche
all engines use oil.
Dave
RE: Quote: "No leaks so far, but it is too soon to tell if this was a fix for the 2qts of oil lost in 6500 miles. I took the old valve cover apart and can't ID a problem. What I do know is that the #1 spark plug hole had about 1" of oil in it. Also, the outer peripheral area was leaking in a few areas but (IMO), not nearly enough to account for 2 qts and not a drop on the garage floor. I keep looking at the coolant for signs of oil - not there." end quote.
Using only 2 qts in 6500 miles is very little and normal. All internal combustion engines burn oil. It is going out the tailpipe. so, it's not the seeping valve cover.
Tightening that valve cover needs to be done incrementally, staggering starting from center, working up to 12.5 nM (9 ftLb) in 3 or 4 steps, especially since this cover is not metal.
09R56
Nov 16, 2022 10:49 AM
schwac2
Sep 11, 2015 11:13 AM
PaulWalliDumali
Aug 21, 2015 04:46 PM
OutMotoring
Aug 6, 2015 09:32 AM
eliseo1981
Aug 6, 2015 05:00 AM
