R50/53 Error code mystery
Old Feb 24, 2015 | 04:56 AM
Indie's Avatar
Indie
Error code mystery
Hey all,
I have recently pulled an error code from my r53 and cant seem to get an answer as to what it is as it isn't a p code.
I went through the system manually to find it.
922800
Any help would be amazing. It has to relate to something right?
Old Feb 24, 2015 | 06:14 AM
Vkng's Avatar
Vkng
61356922800 is the part number for the ECU. Do you have a CEL?
Old Feb 24, 2015 | 06:19 AM
Indie's Avatar
Indie
Yeah the cel is on
Old Feb 24, 2015 | 06:20 AM
Vkng's Avatar
Vkng
Originally Posted by Indie
Yeah the cel is on
Get the code read by an OBD scanner to find out what it is, you likely won't get anywhere with what you got from the menu.
Old Feb 24, 2015 | 06:36 AM
Indie's Avatar
Indie
Ive tried to find an affordable scanner that will work with the r53 and so far no luck. Any canadian options that wont break the bank?
Old Feb 24, 2015 | 06:40 AM
Vkng's Avatar
Vkng
You can get the cheap wifi / bluetooth (bluetooth only works on Android) OBD scanners that can work with your phone off of Amazon for cheap. I'm not sure about Canada, but try calling around to different auto parts stores or some shops and ask if they can pull a code for free. It only takes a couple of minutes, if that, so someone should be able to do it for you.
Edit: Looks like maybe Aamco in Canada will do it for you.
Old Feb 24, 2015 | 08:55 AM
Indie's Avatar
Indie
Alright ill look into aamco. Do you know which wifi obd prog supports mini?
Old Feb 24, 2015 | 09:24 AM
Vkng's Avatar
Vkng
They all should. I use Torque for Android, I think the free version lets you read codes. I've heard Dash Command is good for iOS.
Old Feb 24, 2015 | 02:01 PM
Indie's Avatar
Indie
Seems the code is p2096. Anyoneknow?
Old Feb 24, 2015 | 02:40 PM
mgriffin1300's Avatar
mgriffin1300
I really believe my throttle positioning control is frozen. It has not been running very good at low RPM in this bitter cold but ran fine at highway speeds. All this just this morning when it went into limp mode. P1639 throttle position valve stuck permanently P0120 throttle / pedal position sensor / switch A circuit malfunction P1638 throttle stuck. It's been 10 to 15 below 0 every night and only getting into single digits during the day. Mini has a pretty lousy design for these.
Old Feb 24, 2015 | 03:35 PM
05r50's Avatar
05r50
http://lmgtfy.com/?q=R53+p2096
Old Feb 24, 2015 | 04:48 PM
ZippyNH's Avatar
ZippyNH
Originally Posted by 05r50
LOL...
LOVE IT!!
Old Feb 24, 2015 | 05:33 PM
Indie's Avatar
Indie
If you had the time to do that you probally could have helped with an answer instead.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
hamptup
R55 :: Clubman Talk (2008+)
18
Nov 29, 2016 05:04 PM
MiniSkoon
Sep 9, 2015 12:40 PM
MasterShaftner
Sep 4, 2015 03:52 PM
