R57 How slow do I need to go to downshift in to first gear?
Hey All,
Odd question! I feel like I have to drop my speed quite low (Below 5 miles an hour) to get in to first while coming to a stop, is that normal? I feel like most of my other manual transmission cars were not like this, is this normal of second gen mini's?
You can do a double-clutch if you absolutely have to get into first gear while you are moving. Otherwise, it's best to just come to a stop, then shift to first and start moving again.
I never shift to first unless I am at a full stop or moving no more than 2 or 3 mph.
What you are describing sounds very normal of any modern manual transmission I have driven, and our MINIs are no exception.
Never...
Consider first just to get moving.
When coming to a stop, just keep it in third of second, till you feel a flight lug, go to neutral, and normally you should be rolling to a stop in a moment....
Do you Rev Match prior to attempting to drop it into First Gear?
I don't use First Gear to slow... If I'm on the track and I need to drop to first, I do it after the majority of braking and I shift (rev match) so I can accelerate out but it takes a really sharp turn to get me to drop below second on track.
I have always taught... brakes are cheaper than clutches and transmissions...
Motor on!
Motor on!
Nope, an 04 Cooper was my first stick. It was used and had 70,000 miles on it. I blew that clutch in, oh, 3 months? Then I moved to a Vespa PX (shifter) when I got rid of the mini, then a hyundai accent (manual). the clutch in the hyundai is very soft, and I can get in to first without being completely stopped (at a stop sign) So I think driving that has kind of thrown me off. Plus, having bought a used mini the first time, I think I'm more paranoid than I should be. I also bought it from a shady third party dealer, never a good idea!
I never downshift into first. I've been driving since 1977 and have never had an automatic and have never replaced a clutch. I'd say that if you're going slow enough to downshift into first you should just shift into neutral and use your brakes or coast...if you start moving again before coming to a stop you can do it in second. I'm not sayin' I'm right, that's just how I do it.
unxpectederror
Oct 22, 2015 12:16 PM
MINI Stupor
Oct 1, 2015 11:36 AM
