R57 How slow do I need to go to downshift in to first gear?
Old Feb 23, 2015 | 11:25 AM
Joewp's Avatar
Joewp
Hey All,
Odd question! I feel like I have to drop my speed quite low (Below 5 miles an hour) to get in to first while coming to a stop, is that normal? I feel like most of my other manual transmission cars were not like this, is this normal of second gen mini's?
Old Feb 23, 2015 | 01:17 PM
MrElusive's Avatar
MrElusive
You can do a double-clutch if you absolutely have to get into first gear while you are moving. Otherwise, it's best to just come to a stop, then shift to first and start moving again.
I never shift to first unless I am at a full stop or moving no more than 2 or 3 mph.
What you are describing sounds very normal of any modern manual transmission I have driven, and our MINIs are no exception.
Old Feb 23, 2015 | 01:26 PM
ZippyNH's Avatar
ZippyNH
Never...
Consider first just to get moving.
When coming to a stop, just keep it in third of second, till you feel a flight lug, go to neutral, and normally you should be rolling to a stop in a moment....
Old Feb 23, 2015 | 01:28 PM
JABowders's Avatar
JABowders
Veteran: Army
Do you Rev Match prior to attempting to drop it into First Gear?
I don't use First Gear to slow... If I'm on the track and I need to drop to first, I do it after the majority of braking and I shift (rev match) so I can accelerate out but it takes a really sharp turn to get me to drop below second on track.
I have always taught... brakes are cheaper than clutches and transmissions...
Motor on!
Old Feb 23, 2015 | 03:11 PM
Joewp's Avatar
Joewp
Great, this is likely just me being paranoid with a new car! Thanks for the input!
Old Feb 23, 2015 | 03:33 PM
Capt_bj's Avatar
Capt_bj
is this your first stick?
imo one never shifts down to first unless at a full stop ...
but I've only driven stick for 40 years . .
Old Feb 23, 2015 | 03:38 PM
Joewp's Avatar
Joewp
Nope, an 04 Cooper was my first stick. It was used and had 70,000 miles on it. I blew that clutch in, oh, 3 months? Then I moved to a Vespa PX (shifter) when I got rid of the mini, then a hyundai accent (manual). the clutch in the hyundai is very soft, and I can get in to first without being completely stopped (at a stop sign) So I think driving that has kind of thrown me off. Plus, having bought a used mini the first time, I think I'm more paranoid than I should be. I also bought it from a shady third party dealer, never a good idea!
Old Feb 23, 2015 | 05:07 PM
ShipM8's Avatar
ShipM8
I never downshift into first. I've been driving since 1977 and have never had an automatic and have never replaced a clutch. I'd say that if you're going slow enough to downshift into first you should just shift into neutral and use your brakes or coast...if you start moving again before coming to a stop you can do it in second. I'm not sayin' I'm right, that's just how I do it.
unxpectederror
Oct 22, 2015 12:16 PM
MINI Stupor
Oct 1, 2015 11:36 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
kevinlhr310
Sep 27, 2015 02:31 PM
Rainforest_Elf
Sep 15, 2015 12:11 PM
