R60 question about Rear Cupholders
We just bought a used 2012 Countryman S, with the Split Center Rail, Factory Armrest and rear Bucket Seats. MINI Mania states that the Rear Cupholder kit that mounts at the end of the Front Rail[ on the floor] will fit our Countryman. However, I had some co-workers call MINI Parts Hotline and they said no, the front rail is too long on the 2012 until they modified it for the 2013 model .
Has anyone with a 2011 or 2012 Countryman added the floor mount kit to their MINI? The 'Pod" style Rear Rail Cupholders were already broken or about to break when we bought the MINI, so just replacing them doesn't look like a good long term option if they're that fragile.
MINI Mania Kit- G2NMI1513 $155.
If it helps, we don't have the power outlet at the rear trim on the Front Rail, just a blanking plate in the middle of the plastic trim cover.
Thanks for any help you can provide.
I just pulled up a 2012 CM S on RealOEM. Not sure how long the half rail is but you can select your vehicle and production date here.
Parts numbers found at link.
http://www.realoem.com/bmw/showparts...21&hg=51&fg=35
Here is the image it shows. with and without
x2 i have a center armrest on a 2012 and added the rear cup holder a couple weeks ago with no issues at all.
I just put front and rear cup holder upgrades into my 2011 last week, no problems here either. And kudos to everyone that gathered the info and helped me along the way with my questions.
Paid $163 for BOTH front and rear parts from ECS Tuning, including shipping from Ohio, so your final price may be a little different, but I'd wager it's much less than MINI Mania. Quick check on their website is $108.43 before shipping.
Also make sure you order the correct part number for the Cup Holder Lower Section if you do or don't have a factory installed Front Center Armrest.
Note that you have to order a pair of each of the rubber parts but you only need to order one screw and nut because you can reuse the three that already attach the installed trim piece (1).
You'll need a 13mm socket wrench to install the metal bracket and a T20 Torx driver for the screws.
51169812558 Cup Holder Angle Bracket (9)
51169812554 Mount For Rear Cup Holder (8)
51169813055 Cup Holder Lower Section (5) WITH Front Center Armrest
51169812555 Cup Holder Lower Section (5) WITHOUT Front Center Armrest
51169812556 Cup Holder Upper Section (7)
51169812557 (2x) Cup Holder Insert Rubber (6)
51169811184 (2x) Rubber Insert for Cup Holder (10)
07147136006 Fillister Head Self-Tapp Screw w Collar ISA ST4,2X16 (12)
07146988451 C-Clip Nut (13)
Thanks for all the great replies. so it sounds like it's not a big deal at all. Any one have any pictures of their rear cupholders installed?
A very big thanks to the OEM pictures, we have the 'flat' trim end cap on the rail with that oval blanking plate as pictured in the OEM drawings.
So to add fire to our mix, I test drove a 2012 Clubman S last night with some real thoughts about trading my 2002 Montero Limited in for it.
Another CPO vehicle, with 30,000 miles, Pepper White, with Carbon Black interior, and Auto trans. The Automatic doesn't bother me in the least, and the only real sticking point will be if my Mother-in-Law can easily fit into the R/F seat, and get out again... Insert your own jokes here...
Also, her wheelchair needs to be able to fit through the rear barn doors and into the rear with the seats folded up. That WOULD be a deal breaker as at least one of our vehicles has to be able to transport her and either a walker or a folded flat wheelchair.
I will test the wheelchair for a fit on Saturday Morning, so who knows, we may be a 2 MINI family by this weekend
Looks very nice. thank you. I can see that I will need to get the different end cap for my rail, and probably want to add the power socket as well[ ours lives at the far end of the rear rail on our Countryman]
Maybe you need to post a photo too. I'll post photos with everything disassembled if that helps at all.I can see relocating the power socket (sounds like it's between the rear seats?), so that it doesn't intrude on the foot well or get kicked, but it would get reverted to the original design purely by the fact that rear buckets are no longer available in the US.
I'm pretty sure that the end cap #1 and the blanking plate #3 are what we have. Car is not in front of me, so I will post a picture last tonight.
Looks to me that I need #5 end cap and any associated parts to go with it, plus the lighter socket to fit into #7
OK, I think I got confused with what you were describing.
How about this?
61346973037 Plug-In Socket (1)
51167052720 Luminous Ring, Orange (2)
Not sure how you go about finding a 12V power source if there isn't one there...
http://www.realoem.com/bmw/showparts...hl=2&lang=enUS
How about this?
Thanks for the order
How about this?
How about this?
I took off the blanking plate and looked inside the front rail.
Not as cluttered as I thought it might be considering that the parking brake cables head towards the rear of the rail, so running power from the Front Lighter/Power Socket back to the end of the rail won't be that bad of a job.
Thanks again for all the great info. I won't touch base with this thread until I order my parts and start taking pictures of the install/mod work to post in the future.
Parts order in with ECS Tuning for the rear cupholder parts and add-on lighter/power socket that sits between them. I'll take picutres of the job once I get around to it. Thanks again for everyone's help and info with this.....
: thumbsup:
Thanks, the extra cupholders are so nice and very handy. Thanks for the order .
Any update Pure Red ?
I'm confused, I created a whole thread on the install of these parts some time ago????
that WAS the update, complete with pictures that I took during the work.
Sorry did not see the new thread linked.
Was just checking up on this.
ECS has the kit as one part #...
ECS has the kit as one part #. Going to order it today. At the moment, it's only $113 and change. I've been wanting to do this for a while but never found it cheap enough. ECS is just cheap enough for me to pull the trigger.
Rear Cup Holder for Countryman with Factory Armrest
Thanks,
Tim
Thanks,
Tim
+1 we have the kits with and without front armrest.
51169813055KT Rear Cup Holder for Countryman with Factory Armrest
OR
51169812555 KT Rear Cup Holder for Countryman without Factory Armrest
OR
Both systems are back in stock.
Navigation & Audio Audio system power issues?
jeffbeckhudd
Aug 29, 2015 09:11 PM
Minibeagle
Aug 13, 2015 10:00 AM
