R52 Rear Parking Sensors (PDC) not working
Old Jan 18, 2015 | 04:58 AM
Gizmotech's Avatar
Gizmotech
It has never worked since I purchased it a month ago. When I put it in reverse, the is no beeps heard. I have checked the PDC/PAS Fan Fuse and that is intact. I plugged in INPA and got the following:
24 voltage ultrasonic sensor general
Error frequency : 50
Short circuit to ground
Error present
Can someone point me in the right direction please. Thanks
Old Jan 18, 2015 | 09:10 AM
ZippyNH's Avatar
ZippyNH
The rear pdc sensors shares the same fuse as the PS fan on "refresh", aka 2005+ cars...
So bet the is fan is siezed, fuse blown...
Edit..saw you check the fuse..
Guess that leaves a bad sensor or bad wire...
Me...a mini is so small...always thought the pdc was overkill....
Old Jan 18, 2015 | 09:29 AM
Gizmotech's Avatar
Gizmotech
The convertibles are not easy to park. The entire rear view is restricted. If it was the sensors, it would state short or open circuit to sensor though would it not? And I can't see all sensors going at the same time or having a short.
Old Jan 18, 2015 | 11:41 PM
BigGunz's Avatar
BigGunz
They're not necessarily difficult to park either...the use of mirrors is a lost art.
Old Jan 19, 2015 | 05:39 AM
Bearybee's Avatar
Bearybee
How ironic...I logged in to post about my reverse lights and PDC not working since I purchased back in October and saw where someone is posting the same question. Do your reverse lights work? I have been down the same route with checking the fuse. I have a new reverse sensor and suspect the old one was broken when the clutch was replaced prior to me owning it. There's one problem, I can't find where it is located. I ordered a Bently manual last week and waiting for it to come. I checked online and read to remove driver's front wheel and shine a light on tranny and you will see it. Well, I didn't see it. Any thoughts?
Old Jan 19, 2015 | 06:43 AM
ZippyNH's Avatar
ZippyNH
Think the switch for the rear backup light UNDER the airbox in the engine bay...on the outside of the tranny....
Seems to come up regularly with clutch changes...folks often forget to plug it in..so no backup lights.
Old Jan 19, 2015 | 06:49 AM
Bearybee's Avatar
Bearybee
Thanks! That's what I've read is that they are either knocked and broken or do not get plugged back in. I'm going to go and check it out now.
Old Jan 19, 2015 | 07:01 AM
ZippyNH's Avatar
ZippyNH
Sure not under the seat...lol...car would have to be REAR WHEEL DRIVE for that.....not sure what type of car you were reading about.......now the edit says..wheel...lol..that place you read about this stuff is crap!!
Old Jan 19, 2015 | 07:12 AM
Bearybee's Avatar
Bearybee
Lol...this is true. You were correct, right under the air box. I sprayed a small amount of penetrating oil on it and will change it this evening. I noticed when I unplugged it, the connection was saturated with what looked like trans fluid.
Old Jan 21, 2015 | 05:54 PM
Bearybee's Avatar
Bearybee
Replace your reverse switch. I replaced mine and now have backup lights and the PDC works as well. Easy job; 30 -45 mins.
Error present
Old Jan 21, 2015 | 05:55 PM
Bearybee's Avatar
Bearybee
Also,worst case scenario, you throw $18 away.
Old Jan 24, 2015 | 09:57 AM
Gizmotech's Avatar
Gizmotech
But my reverse light works. Just not the PDC
Old Jan 24, 2015 | 03:34 PM
Bearybee's Avatar
Bearybee
I didn't realize the lights do work. I realize that mine only beeps if I'm within 2 or 3 feet from something. Have you tried putting it in reverse while the key is in the run position and then walk behind the car? You can do this with the engine off and will be able to hear a beep.
Old Jan 24, 2015 | 03:38 PM
Bearybee's Avatar
Bearybee
I ask this only because I still didn't think mine worked at first.
Old Jan 25, 2015 | 09:53 AM
Gizmotech's Avatar
Gizmotech
Yes, I have tried all this. Its definitely not working and I am also not getting an initial beep when I stick it in reverse. The reverse light comes on fine, Fuse 40 (PDC and PAS FAN) is intact. INPA is showing a current fault as every time I clear the fault, the fault comes immediately back on whether I engage reverse or not.
Old Jan 25, 2015 | 09:58 AM
Bearybee's Avatar
Bearybee
Okay, mine doesn't have an initial beep when I engage reverse.
I wish I could offer more help. I wonder if it would throw a fault if you unplugged one or all sensors?
Old Mar 5, 2016 | 05:40 AM
Gizmotech's Avatar
Gizmotech
Outcome: 2 sensors where gone so replaced them and its working all good now.
Old Mar 7, 2016 | 11:27 AM
Yea, you can put your ear on them with the car in reverse, you should here them tick,,,tick,,,tick, if you dont hear in on one or two of them, each one of those are bad, they get water past the seal from high pressure cars washes or pressure washers. I know this as I ave an R52 and know people that go through automatics. You can get them black or painted by color, you can not get them primed and paint them as the paint process applies a very thing coat of paint so the PDC sonar cannot bounce back.
https://www.northamericanmotoring.co...-up-paint.html
Old Apr 8, 2016 | 10:39 AM
Sidewalksam's Avatar
Sidewalksam
you can set the system to give you a test beep each time the car is put in R or not. I had a recent problem where the beep was on constantly when the car was in R. Carefully washed the sensors and now all is back to normal. if you found the right fuse and the car displays reverse lights and the sensors are clicking when in R as stated above I would find and check the speaker/horn that is making the noise and ensure it is not damaged or if the wires to it are intact.
Old Apr 19, 2018 | 05:43 PM
RLucky82's Avatar
RLucky82
I get the dreaded constant beep as soon as I put mine in reverse. will try these tips. ...hey the search feature worked
Old Apr 20, 2018 | 08:03 AM
Yep, they get water in them and fail. I got the water out of mine with a hairdryer, but then the next heavy rain it got water in it again. Then i just replaced it.
Old Sep 24, 2023 | 04:40 PM
JFkukura3's Avatar
JFkukura3
Were they hard to change?
Old Sep 24, 2023 | 04:50 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Mine were working a while back then stopped. Will try a listen if I hear any ticks. Fuse is hood.
Cereall
Sep 5, 2019 06:05 PM
emulajavi
Dec 24, 2018 09:15 AM
Toolman
Jan 20, 2016 06:50 AM
squawSkiBum
Oct 2, 2015 09:21 AM
