215/60r17 snow tires 2015 countryman
Old Jan 6, 2015 | 02:39 PM
Coopercountry's Avatar
Coopercountry
Does anyone know or is anyone currently running these size tires on their countryman 215/60r17. I can get a good deal on 4 but only want to grab them if they will fit.
Old Jan 7, 2015 | 11:45 AM
MyroMini's Avatar
MyroMini
I'm running 215/55R17 Nokian Hakka7 on my JCW and no issue
Old Jan 7, 2015 | 02:05 PM
Coopercountry
Thank you!!! This is awesome news I am going to go and get these tires tonight. I will probably get them installed this weekend. Let ya know how everything turns out. How do they look and ride on your JCW???
Old Jan 8, 2015 | 08:15 AM
Alex@tirerack's Avatar
Alex@tirerack
Just to confirm your tire size is almost 1" taller than Myro's.
Old Jan 8, 2015 | 09:33 AM
Coopercountry
I know, at first I didn't realize that Myro was running 55's. Do you know if the 215/60's will fit a 2015 countryman on the stock 17in wheels?
Old Jan 8, 2015 | 01:09 PM
bmwr606's Avatar
bmwr606
i am running 205/70R16 winters on mini oem euro alloy 16x6.5 et 46 wheels on my all4
the tires have an od of 27.3 inchs and i have the factory sport suspension, 10 mm lower than the standard suspension
no rubbing or other clearance issues
Old Jan 9, 2015 | 12:45 PM
Alex@tirerack
The tires have an od of 27.3 inchs .....no rubbing or other clearance issues
Great to know, Your 215/70's are only 27.1".
@ bmwr606, do you think you could accommodate the 1/4" more width on each side?
I am checking with my tech team on this one as well.
Old Jan 9, 2015 | 01:42 PM
Alex@tirerack
@ Coopercountry
Is yours an all4 ?
Old Jan 9, 2015 | 02:22 PM
Coopercountry
Yes it's an ALL4
Old Jan 9, 2015 | 02:42 PM
bmwr606's Avatar
bmwr606
yes, i have at least 1/4 inch clearance
my wheels are 16x6.5 et 46 ...
my CM ia an all4 with factory sport suspension
Alex, i bought the tires from you ... dunlop grandtrek sj6
Old Jan 12, 2015 | 01:19 PM
Alex@tirerack
Looks like clearance is pretty close when turning lock to lock. We get as close as 18mm. Not much room for packed snow or ice.
Old Jan 13, 2015 | 12:29 AM
bmwr606's Avatar
bmwr606
205/75R16 front tires rubbed at less than full lock with 4 - 200 pound plus guys sitting in the car ... car was sitting on the front bump stops
the rears rubbed when 2 more 200 pound plus guys sat in the open boot .. car was sitting on the rear bump stops
no rubbing under the same conditions with the 205/70R16 tires
i have not had a problem with packed snow/ice limiting steering with the 205/70R16s
Kimolaoha
Dec 5, 2020 09:32 PM
woodstudio
Mar 15, 2020 08:28 AM
kazyn
Oct 25, 2019 02:34 PM
peicraig
Canada
Aug 22, 2015 07:48 PM
col127
Aug 21, 2015 02:11 PM
