R56 Engine bay vent delete?
Old Sep 27, 2014 | 08:20 AM
rryan1912's Avatar
rryan1912
Engine bay vent delete?-image.jpgSo I was looking around in my engine bay and I noticed a plastic vent below my wiper fluid. I didn't know what it was, so I followed it to the back of the engine underneath my air intake. The vent doesn't connect to anything, I think it just provides more air to the bay. I'm looking to clean up my engine bay and I was wondering if anyone else has deleted this vent and how to delete it if anyone has. Would this also cause any problems temperature wise if I removed it?
Thanks,
Ryan
Old Sep 27, 2014 | 08:26 AM
Grizld700's Avatar
Grizld700
The vent connects to the stock air filter assembly. If you have an aftermarket then it may not be used. However, it will still let cooler air reach the aftermarket filter better, therefore providing a theoretical performance advantage.
Old Sep 27, 2014 | 08:33 AM
rryan1912's Avatar
rryan1912
I have an aftermarket air intake, so I would be able to remove the vent? Please correct me if I'm wrong.
Old Sep 27, 2014 | 08:38 AM
Grizld700's Avatar
Grizld700
Which intake are you running?
Old Sep 27, 2014 | 08:39 AM
Grizld700's Avatar
Grizld700
NVM. I see the Nm intake there. Yeah you can remove it.
Old Sep 27, 2014 | 08:40 AM
rryan1912's Avatar
rryan1912
Ok thanks. Any idea on how to remove it?
Old Sep 27, 2014 | 08:44 AM
Grizld700's Avatar
Grizld700
It's just a slip and clip kind of fitting. Screw driver with cloth around the tip (to keep from scratching the plastic) should do the trick. Slides right out. I can almost do it with just my hand on mine. Or if you have a plastic trim tool, that would work even better. Either way, pretty easy peasy.
Old Sep 27, 2014 | 08:47 AM
rryan1912's Avatar
rryan1912
Awesome! Thanks for the help.
Old Sep 27, 2014 | 08:50 AM
Grizld700's Avatar
Grizld700
No problemo!
Old Sep 27, 2014 | 08:52 AM
rryan1912's Avatar
rryan1912
I just found that the vent is connected to a metal plate. Might need an Allen key but I'm not sure.
Old Sep 27, 2014 | 08:53 AM
Grizld700's Avatar
Grizld700
What year and model do you have?
Old Sep 27, 2014 | 08:54 AM
rryan1912's Avatar
rryan1912
2012 r56S
Old Sep 27, 2014 | 08:57 AM
Grizld700's Avatar
Grizld700
Ok. There may be a difference then. I have a '07 R56S and that has the N14 engine. Yours should be the N18 engine. Perhaps they changed how they connect to the front area there. In mine, there is no bolts or screws. Yes it connects to the metal plate, but its just a snap fitting.
Old Sep 27, 2014 | 08:58 AM
Grizld700's Avatar
Grizld700
There is a collar piece near the front. See the picture:
In your picture you show #8. That connects to #9. And #9 connects to the front.
Old Sep 27, 2014 | 09:02 AM
rryan1912's Avatar
rryan1912
So I should be able to just pull #8 out from #9, and then pull off the metal plate from #8?
Old Sep 27, 2014 | 09:05 AM
Grizld700's Avatar
Grizld700
Heck, if its too much of a hassel, I'd just leave #9. You wouldn't even see it under there.
Old Sep 27, 2014 | 09:07 AM
rryan1912's Avatar
rryan1912
Ok I'll leave that but remove #8
Old Sep 27, 2014 | 09:34 AM
rryan1912's Avatar
rryan1912
Just took it out, thanks for the help!
Old Sep 27, 2014 | 09:35 AM
Grizld700's Avatar
Grizld700
Woohooo! Glad to hear it!
Kimolaoha
Jul 5, 2023 01:04 PM
blackie
Jan 18, 2017 09:57 PM
blackie
Jan 18, 2017 09:56 PM
makg
Aug 21, 2015 02:49 AM
chicohuahua
22
Aug 20, 2015 11:17 AM
