F55/F56 Post Run Flat Shoes
Old May 2, 2014 | 02:14 PM
Mrdi's Avatar
Mrdi
Post Run Flat Shoes
Might as well start deciding on what goes on after the run
flats.
To start, I usually go to TireRack and see what is the best rated.
More run flats?
High performance with stiff sidewalls?
Old May 2, 2014 | 02:41 PM
ThumperMCS's Avatar
ThumperMCS
Michelin Pilot Super Sports
Hands down the best tires out there...$$ but worth it. Last a long time too
Old May 2, 2014 | 02:55 PM
RobMuntean's Avatar
RobMuntean
Originally Posted by Mrdi
Might as well start deciding on what goes on after the run flats. To start, I usually go to TireRack and see what is the best rated. More run flats? High performance with stiff sidewalls? ??
I'd recommend Conti DWS or DW(summer) tires.
Old May 2, 2014 | 03:36 PM
dwdyer's Avatar
dwdyer
Originally Posted by robmuntean
i'd recommend conti dws or dw(summer) tires.
+1
Old May 2, 2014 | 05:07 PM
GregoryK's Avatar
GregoryK
Michelin Pilot Super Sports. Really pavement glue. Best tires I have ever owned.
Old May 2, 2014 | 07:35 PM
MotorMayhem's Avatar
MotorMayhem
agreed, they will be going on mine when the time comes.
Old May 3, 2014 | 06:32 AM
ceoengr's Avatar
ceoengr
+1. I have these on all my steeds in the stable. Awesome tires for my needs and taste.
Old May 3, 2014 | 07:12 AM
thefarside's Avatar
thefarside
flats.
More run flats?
Your driving style is? (Pedal-to-the-metal, grocery getter, other?)
Rim size is?
Location? (If you live in the southwest, for example, tires age faster there than in the northeast)
Did you want separate tires for summer and winter or would A/S do?
Budget?
If you are OK with A/S then you will be hard pressed to do better than the Conti Extreme Contact DWS. I live in Az, tires age fast out here, as a result they tend to lose wet traction sooner than a cooler climate. The DWS is far better in that respect than any other tire I've used, in fact the DWS has great wet and dry traction.
FYI, Going from RFs to conventional tires means you will lose some lateral stiffness.
While I've not used them, the Bridgestone Sport RE760s have also been spoken of well.
Old May 3, 2014 | 08:48 PM
marcussoori's Avatar
marcussoori
Already installed on mine...awesome tires...
Old May 6, 2014 | 01:53 PM
Mrdi's Avatar
Mrdi
All valid concerns.
My home is along the coast in southern CA.
Sunny,salty, rarely rains, rot is a concern.
I'm too old to be a hot rod.
Too young not to order a manual.
Not too worried about longevity.
300 rating on the rubber compound is minimum.
I typically sport Michelins on my vehicles, 911, MB Sprinter, and now
a MCS manual in Moonwalker Grey.
Old May 7, 2014 | 09:05 AM
tigerhonaker's Avatar
tigerhonaker
flats.
More run flats?
On the 2011 MCS we traded in I went with the, Michelin Pilot Super Sports.
2011 Mini Cooper S W/ 205/45/17 Michelin Pilot Super Sport Tires
https://www.northamericanmotoring.co...ort-tires.html
But .........
This time I am "Not" going to go with any tire that is not a Run-Flat.
The 2014 MCS we just took delivery on has the optional 18" wheel & tire package.
It drives smooth in the default position with no real adverse roughness.
So, when it comes time to change tires I'll just check and see who has the best rated Run-Flats in the 18" size and go with them.
Terry aka "tigerhonaker"
Old May 7, 2014 | 04:24 PM
randomquickness's Avatar
randomquickness
+1 on the MPSS. I've had excellent results with them. Although I am still thinking I might just do a set of super sticky summers like 200 or less treadwear rating.
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
ltjpunk7
Sep 6, 2015 07:32 AM
TJANK
Aug 24, 2015 06:11 PM
Powershift
Aug 16, 2015 05:14 PM
sabjcw
Aug 14, 2015 07:40 AM
