Navigation & Audio Stereo Install?
Old Apr 28, 2014 | 07:35 PM
Ballsy's Avatar
Ballsy
Stereo Install?
Hello all. This weekend I plan on installing a new stereo in my 04 justa. Is there anything I should know, wires in specific? What colors are which on the factory harness? And would crimping the wires together be okay? Thanks for everything.
Old Apr 28, 2014 | 09:03 PM
bjcarter2's Avatar
bjcarter2
I installed a Pioneer DEH-80PRS I purchased from Crutchfields. With the instructions provided, it was a very straight-forward and easy install using the provided adapter harness.
The install instructions and wiring diagram are linked below.
The wiring adapter I used was Metra 70-9003C. It worked like a champ.
You'll need this too for radio reception - Euro Antenna Adapter OEM F to Motorola M
And this for the mounting adapter - Metra 99-9302 In-dash Receiver Kit
https://drive.google.com/file/d/0B-K...it?usp=sharing
Old Apr 28, 2014 | 10:49 PM
MiniMeep's Avatar
MiniMeep
What bjcarter2 said....
You shouldn't need to be cutting and crimping cables, you can do everything via harness adapters and kits for the antenna and fascia.
Old Apr 29, 2014 | 04:23 AM
Striped Toad's Avatar
Striped Toad
Definitely spend a little $ and get a wire harness. Don't Mickey Mouse around when you can securely plug and play. Other than that, it's pretty simple install.
Old Apr 30, 2014 | 04:42 PM
Ballsy's Avatar
Ballsy
Well I already bought a stereo from walmart, and it has the harness sticking out the back for the wire connections. So crutchfield is out of the question. I would like to know the colors of the wires for the power, ground, front speakers, rear speakers, and any extra. Thanks!
Old Apr 30, 2014 | 04:59 PM
bavmotors's Avatar
bavmotors
Should be able to look up the colors and what they mean on the google.
Old Apr 30, 2014 | 08:03 PM
MiniMeep's Avatar
MiniMeep
At the very least you will need that fascia adapter as the original mini stereo fascia is oversized.
Also unless you bought a no name stereo you can get the adapter for all the major brands.
Check out the links in Post #2 that has the wiring info that you are after
Old Apr 30, 2014 | 10:42 PM
rkw's Avatar
rkw
Is the same headunit sold by Crutchfield? You may be able to buy a wiring adapter from Crutchfield.
There is a pin and wire diagram here: https://www.northamericanmotoring.co...nd-system.html
bjcarter2's Avatar
bjcarter2
Here ya go!
2004 Mini Cooper Basic Sound System Wiring Diagram
Old May 1, 2014 | 09:01 PM
jeffl's Avatar
jeffl
The wires on the Walmart stereo get crimped to the harness adapter. Then plug the adapter to factory harness.
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
