Interior/Exterior Best way to get replacement headlight lens
Old Feb 19, 2014 | 08:59 AM
Javskies's Avatar
Javskies
so this happened to one of my lenses, dont ask me how:
ive tried everything to fix it with no results so i was wondering the best way to get a replacement. will i have to buy a used headlight and take the lens off? would a halogen housing lens fir onto my bi-xenon? thanks!
Old Feb 19, 2014 | 09:29 AM
Minian's Avatar
Minian
Go to ebay and buy a new set, or face the dealer price.
Option 2, go to a salvage yard or online salvage site and buy another HL.
Old Feb 19, 2014 | 10:06 AM
ZippyNH's Avatar
ZippyNH
You have a gen1 judging by you other postings....
so no Bi-Xenon.....
You have Xenon lows/Halogen Hi beams....
There were 2 different versions....
a pre 2005 reflector version..pretty cheap used (comparatively), and the 2005+ gen1 "facelift" version...with lenses..pretty $$$, even used, but much better working.
Old Feb 19, 2014 | 10:14 AM
Javskies's Avatar
Javskies
so the pre facelift lens is a different shape than the post facelifts?
Old Feb 19, 2014 | 10:17 AM
IQRaceworks's Avatar
IQRaceworks
Looks like you tried sanding on it? Go out and buy one of the 3M headlight restorer kits. Those thing WORK...and work very well. Might want to try that before going out and getting new lights.
Old Feb 19, 2014 | 10:52 AM
yetti96's Avatar
yetti96
+1 for headlight restoration, 1000 grit wet, then 3000 grit and then buff wheel using plastix and a final sealant/protective coat of a plastic sealer and you are good to go.
Or buy new headlights, they don't sell just the lens.
Old Feb 19, 2014 | 10:59 AM
rkw's Avatar
rkw
Tell us what you've already tried to fix it.
If you do get a new or used replacement headlight, just swap the entire housing. The lens is bonded to the housing and not designed to be removable.
Old Feb 19, 2014 | 11:13 AM
c0op3r's Avatar
c0op3r
IQRaceworks & yetti96 are Dead on the Money!
Got to Walmart or Amazon and get the
3M Headlight Restoration Kit 3M Headlight Restoration Kit
use this lit with a low speed cordless drill, 15 to 17$ and an hours worth of work and you will headlight that you can be proud of.
Old Feb 19, 2014 | 01:06 PM
Javskies's Avatar
Javskies
you guys are the best! turned out it was the inner part of the lens so i just had to heat it up, take it apart, and use the kit. thanks again guys!
Alkaidovich
Jan 30, 2021 01:35 AM
Rai1gun
R60/R61 Stock Problems/Issues
Jan 11, 2016 05:52 AM
Alkaidovich
Aug 30, 2015 09:04 AM
R53Mom
Aug 17, 2015 01:38 PM
