FS:: Devils own alcohol injection kit
Friend sold his 03 mcs and asked me to sell his Alcohol injection kit so here it is: DDP 5800 I believe it has everything you need except a tank (he used his headlight washer tank) He ran it for about 8 months. Price is 300 obo Buyer pays shipping. Flat rate would be the best way to ship, as the pump is pretty heavy.
If someone gets this kit I have some extra part you might want to add to the system.
I Have:
(a) Devils Own - Brand New 1/2 Gallon Tank - SOLD
(b) Devils Own - Extra Cap
(c) Devils Own - Brand New In-Line 40 Micron Filter
(d) Devils Own - Tank fitting with filter BRAND NEW SOLD
(e) Cooling Mist - Controller / Gauge (I was never able to get this to work correctly) Sold AS-IS also works as a boost gauge (does not show vacuum only boost Ver 1.03 Progressive Controller will work off MAP or Boost or BOTH.
(f) Some sections of hose.
(g) Cooling Mist - Flow Sensor w/ 6mm Quick Connects
(h) Cooling Mist - Check Valve w/ 6mm Quick Connects
(i) Cooling Mist - Inline Filter w/ 6mm Quick Connects
(j) Cooling Mist - Nozzle / Jet Set 90° w/ 6mm Quick Connects x2
(k) Cooling Mist - Low Fluid Sensor
I will accept any reasonable off on this stuff.
I Have:
Is this the Stage 2: Progressive electronic methanol injection control kit or the DVC-30: Stage 2 utilizing built in MAP sensor kit?
The DDP5800 is the pump model for both kits.
http://www.alcohol-injection.com/en/147-cooper-s
I will have to ask my friend today I'm not sure.
Some Notes on W/M Injection . . .
For those that might not know the advantages to Water / Methanol injection.
Acts as Octane Booster
Colder intake Charges
Cleans Intake system (R56 are you watching)
With a system like this installed, you can run anything from purified water 100%, window washer fluid (-32°F is 30% methanol) to mixing your own blend. I run a 70/30 Mix of Methanol/Water home made mix.
I have seen intake charge temperatures less that ambient when the system is injecting under boost.
The systems are easy to install and setup and VERY easy to maintain, basically just add whatever mix you are going to use.
If you have any questions about W/M use and installation feel free to ask in this thread.
Pump
Controller
Jet adapter and some Line (not sure the photo is not great)
Fuse Holder
so you would need to add minimum:
Tank (A)
Tank Fitting (D)
Low level Sensor (K)
Inline Filter (C)
I would also add the check valve (H).
Assuming the jet(s) are not there you would need those also.
If i am looking at his kit correctly he has:
Pump
Controller
Fuse Holder
Tank (A)
Tank Fitting (D)
Inline Filter (C)
Pump
Controller
Fuse Holder
Tank (A)
Tank Fitting (D)
Inline Filter (C)
Ok after looking at devils own website, the parts missing from the complete progressive kit are; screws,zip ties, and some vacuum line. The jets are there!
The wiring was cut so it you will most likely need some extra wiring. The system is 380ish new and this was only used about 8 months.
Interior/Exterior Unboxing Video of Sneed4Speed R53 Brake Cooling Kit
Gremothra
Sep 9, 2015 08:42 PM
M7Speed
Sep 3, 2015 07:27 AM
Sep 1, 2015 03:36 PM
