Navigation & Audio R52 Stock radio question
Old Jan 14, 2014 | 01:48 PM
RodFR's Avatar
RodFR
Hi there!
I have a 2005 R52 Cooper S (European model) and was planning on installing the Sony MEX-BT3100U stereo. Besides the fascia adaptor, I was wondering if it is compatible with my car and if any other parts were needed to install it.
Anyone can assist? Thank you very much in advance!
Best,
RodFR
Old Jan 14, 2014 | 03:23 PM
joylove's Avatar
joylove
https://www.northamericanmotoring.co...questions.html
You may be lucky enough not to need the HK enabler.
Old Jan 14, 2014 | 04:14 PM
RodFR's Avatar
RodFR
So I should be good to go with just the head unit and the fascia adaptor, right? Standard radio, no HK system in..
Old Jan 14, 2014 | 04:21 PM
joylove's Avatar
joylove
you'll need the SOT-976 wiring adaptor and the FAKRA to DIN or ISO adaptor for the antenna.
You'll also need a BMW to Sony steering wheel remote adaptor. Often those can include the SOT-976.
Old Jan 14, 2014 | 04:32 PM
RodFR's Avatar
RodFR
I don't have steering wheel controls, so I assume the adapter won't be needed, right?
In regards to the sot-976, I've tried searching but couldn't clearly understand it's purpose, could you clarify, please? I'll also find out what the antenna adapter is (Din or ISO) and get the right one! Thanks a lot, joylove!!
Old Jan 14, 2014 | 04:55 PM
joylove's Avatar
joylove
The SOT-976 linked converts the BMW 40 pin TYCO Quadlok to two ISO connectors to suit the Sony.
Old Jan 14, 2014 | 05:01 PM
RodFR's Avatar
RodFR
Thanks a lot, joylove! I think I'll be getting the Fakra to din, as it looks like it's the correct one.. Searched but couldn't find the answer to which one sony has..
Old Jan 22, 2014 | 03:35 PM
RodFR's Avatar
RodFR
So I finally got the head unit into my R52 05 MCS, as soon as I have some pictures I'll put them up here!
However, I couldn't connect it to the ignition of my Mini.. Anyone could help with this? Here you have the installation manual and what I got is the Autoleads SOT-976, as kindly suggested by joylove! http://pdf.crse.com/manuals/4427434311.PDF
Thanks again, guys!!
Old Jan 24, 2014 | 08:10 PM
joylove's Avatar
joylove
Find the red and yellow wires on the Sony harness and swap the bullet connectors over.
Old Jan 24, 2014 | 11:05 PM
RodFR's Avatar
RodFR
In the meantime, I found out that the ignition cable was going to a different connector on the SOT-976, one that was not being used by the sony. I ended up using the red wire, stripping it and cutting the one where the ignition was connecting to (harness side, not on the car side), and got it working!
Alkaidovich
Jan 30, 2021 01:35 AM
Aug 19, 2015 12:51 PM
Emnotek
Aug 13, 2015 05:47 PM
veevsato
Aug 5, 2015 04:42 AM
