R58 How did you mount your Blackvue?
Old Dec 25, 2013 | 04:58 AM
kg4fxg's Avatar
kg4fxg
I have a Blackvue with the Power Magic Pro. Trying to decide how to mount it around the rear view mirror. Any thoughts?
Horizontal or Vertical? Or should I opt for on the dash? Not much room in the coupe you know. This is the 2 channel version so there is a rear cam as well.
Just wondering if any one else had done this before?
Old Dec 25, 2013 | 05:14 AM
kg4fxg's Avatar
kg4fxg
Blackvue Mounting....
I drive a 2013 S Coupe. Not sure if my mirror is the same as all Mini's or not. I have the rain sensor package and auto dimming feature.
Not a lot of room behind the mirror. Choose left or right. Middle is hard unless I can mount Blackvue vertically or opt for the dash.
Old Dec 25, 2013 | 08:36 AM
minirab's Avatar
minirab
I'm from the sticks, what is it?
Old Dec 25, 2013 | 09:12 AM
kg4fxg's Avatar
kg4fxg
Blackvue
It is basically a Dash Cam. Will video front and rear while driving. There is an App so with Wifi like when I am in the garage I can watch or view the video. Or take the SD card out and view on computer.
Gets a little more complicated as it will also video activity in Parking Mode. So it will take clips of any movement around your car.
Then you wire it in to your car using the Power Magic Pro and with flip switches you can choose the voltage to turn off so you don't come back to a dead car battery. You can also set the sensitivity and much more via the App.
Here is the website.... http://www.blackvueusa.com/Our-Products.html
Again, just toys and why do I need it, well I don't but just because it is there.
They claim, and I say they claim it will help you in an accident. Say you are driving along a four lane road in town and a car crosses into your lane and hits you. You have video to prove when the other driver says it was your fault you went into his/her lane. So I am told. Does such proof work? I don't have first hand experience with this idea.
Also cool to video Mountain Drives, lots of curves, etc. Some use GoPro cameras. Awesome videos and you can mount GoPro to the Tow Hook for a great view.
You can see much on the website. Also, this website is very good. http://www.blackboxmycar.com Look at some of his videos on You Tube just type in BlackBoxMyCar on You Tube.
The idea is thought provoking anyway. Gimmick? Toys? But then I have to ask why do we choose to add items to our cars after we buy them. Someone else would prefer Racing Lights, Tow Hooks, more Gauges, other Mods.
In the end we have to have our toys. Because they are fun.
Old Dec 25, 2013 | 09:57 AM
bjcarter2's Avatar
bjcarter2
Here's a few accidents caught on a GoPro here in Anchorage...
Unfortunately, I did not have the camera running with I T-boned a '13 VW Golf that ran a stop sign with my '08 Forester Sports XT. Both cars totaled and no one hurt. Thankfully, there was no question that she was at fault.
Old Dec 25, 2013 | 10:11 AM
kg4fxg's Avatar
kg4fxg
Incredible
Always amazed what these things will catch. And I have heard amazingly good things about GoPro.
While I don't want to be in an accident it would be cool to film one. I can see life could be interesting with the camera rolling. Who knows what you will see or film.
Old Dec 26, 2013 | 01:21 PM
minirab's Avatar
minirab
Now I understand! No wonder all the comrades in the ole USSR have
them!!
Old Dec 28, 2013 | 01:41 PM
kg4fxg's Avatar
kg4fxg
Almost Done
Got the Blackvue mounted directly under the mirror as the best spot. If you choose high up either left or right it would be sticking to those little black dots on the window. Wide angle lens so it really does not matter, just preference and taste.
Hardly noticeable, considering I have the auto wipers and all lots going on around the rear view mirror. Also have auto dimming mirrors. Totally different in the wife's Countryman. I guess the mirror is unique to the Coupe.
Got the power magic pro wired into the fuse box on the passenger side. Found always on fuse and one that cuts off say after 30 minutes. Ground you see if you drop the glove box on the right - there is a screw.
Used a coat hanger to gentle pull the wires through from the drivers side to the passenger side behind the console. All hidden now and looks great.
Box mounted to right of steering low.
Still need to run the cable for the rear dash cam. After all this work makes me think real hard about the effort for the remote radar detector. But so be it. I don't speed and often set cruise at the speed limit. Yes, waste of money but I just like to know who is watching me. Strange, but that is me.
I have done so many Amateur Radio installs that running wires is easy. The idea is easy, but it still takes time and can't rush a good job.
Old Jan 29, 2014 | 05:02 AM
kg4fxg's Avatar
kg4fxg
Install Completed
A few pictures of the install.
Old May 21, 2014 | 10:58 AM
seamonkey420's Avatar
seamonkey420
Thumbs up
Thank you for this information!! i'm about to get an OJO DashCam for my 2013 Coupe and was wondering where i would be able to get hardwired power from.
I'll post an update once i get it install and working!!
Old May 21, 2014 | 11:57 AM
seamonkey420
Question higher resolution photo of fuse box, fuse used?
do you have a better photo of the fuse box and which one you used? I'm planning to do a similar install w/my OJO Dash Cam and want a clean, hardwired setup.
Thanks again!
Old May 21, 2014 | 04:26 PM
kg4fxg's Avatar
kg4fxg
Fuses
Well, I used several. Blackvue and MagicPro uses one, Passport Radar uses one and I think one other device.
Here is how I mounted the remote head for the Amateur Radio. It connects under the seat rail. Like two fingers. No holes drilled, I could pull everything out of the car and you would not know it had been there!
Just rear of car with antenna on trunk lid - low profile and black.
Magic Power Pro as I can set the timers and voltage for running Blackvue and not come back to a dead battery.
Old May 21, 2014 | 04:29 PM
kg4fxg's Avatar
kg4fxg
More Photos
Here is the hidden radar box above the gas peddle.
Here is the console notice the radar in ashtray and amateur radio. Sweet! The antenna for the radar is in the rear dash between the seats, good level shot out the windshield and it works great!!! Can't really even see it. Held in place with velcro.
Old May 21, 2014 | 04:32 PM
kg4fxg's Avatar
kg4fxg
Fuses
Here is the fuse box passenger side.
Old May 28, 2014 | 02:24 PM
seamonkey420
Thank you Bill!! i'm doing my wire up tonight. hopefully i don't break my electrical ;P
Old May 28, 2014 | 04:34 PM
kg4fxg's Avatar
kg4fxg
Best of luck
Best of luck with the wiring, not hard, trial and error until you get one that either stays on all the time or cuts off. I just wrapped the wire around one of the fuse ends. With cover on you can't tell I was in there.
Love the Blackvue and Passport in the smokers ashtray. Funny flat spot on the ashtray that is perfect for the display with a square piece of velcro.
You will love the dash cam. Hope you catch some interesting videos but are not part of one. I enjoy watching many drives in the mountains front or rear. I can't compare to GoPro but nice still the same.
Cheers,
Old May 28, 2014 | 09:52 PM
seamonkey420
Thumbs up GoPro FTW!
LOVE MY GOPRO! i took it with me snowboarding in colorado and got a few wipeouts with it. Quality is great and the size is excellent. Also use it in my mini for drives and meetups.
Here's example from the M.U.M meetup (MN United Minis) a few weeks back
NLNB 2014 - Mini Motoring Group Leaving New London - YouTube
"> NLNB 2014 - Mini Motoring Group Leaving New London - YouTube
" type="application/x-shockwave-flash" width="425" height="350">
Filmy
15
Jun 6, 2023 06:27 AM
BRebels
Electrical
20
Jul 31, 2016 02:10 PM
JCW Clubman 2010
Oct 1, 2015 01:57 PM
minimofo
Sep 30, 2015 12:26 AM
Sep 4, 2015 02:34 PM
