R56 Three wheeling is fun but I need the traction.
Old Nov 13, 2013 | 02:21 PM
Christopher Pflaum's Avatar
Christopher Pflaum
My 2009 Mini Cooper S has an upgraded rear sway bar and it keeps going up on three wheels through hard turns. Does anyone know how to fix this problem?
Old Nov 13, 2013 | 02:47 PM
1guru2's Avatar
1guru2
3 wheeling
Stiffer front springs and softer rear springs if possible. Then play with the tire pressure all around. These cars respond well to tire pressure changes both up and down!
Old Nov 13, 2013 | 03:17 PM
v10climber's Avatar
v10climber
Is it causing problems? As in is the car oversteering too much? Get rid of the swaybar and that will help but you'll have a hard time eliminating it completely
Sent from my DROID RAZR HD using NAMotoring
Old Nov 13, 2013 | 05:39 PM
awise82's Avatar
awise82
I thought it looked good running around the parking lot a couple weeks ago, honestly I was jealous.
Old Nov 13, 2013 | 07:51 PM
RJKimbell's Avatar
RJKimbell
If your Sway Bar is not adjustable, I'd replace it with one that is.
Old Nov 13, 2013 | 08:01 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It's OK for it to go on 3 wheels, This happens because the bar is stiffer. You can make it softer, but then you will add back some understeer you had prior to the bar. It's a trade off.
Old Nov 14, 2013 | 05:04 AM
countryboyshane's Avatar
countryboyshane
Yee haw dog' leggin' it! No more understeer
Old Nov 14, 2013 | 09:35 AM
Slave to Felines's Avatar
Slave to Felines
Are you sure you need more traction on the rear? Your car is oversteering too much?
It's not uncommon for cars to lift the inside non-driven wheel when going through a turn very hard. Old VW GTIs are notorious for taking the "pissing dog" attitude, and old 911s will lift one front wheel fairly high as well. I've even seen pics of F1 cars with one front wheel off the ground.
Old Nov 14, 2013 | 09:58 AM
countryboyshane
Yea that's what I think. So one wheel is lifting... big deal.
Old Nov 14, 2013 | 10:10 AM
jkapinos's Avatar
jkapinos
Try two wheelin.
Old Nov 14, 2013 | 11:06 AM
Btwyx's Avatar
Btwyx
We get a wheel lifting and we just have the stock sport suspension. It doesn't seem to cause any problems.
There is a theory that its a good thing. Keeping one tire happy works better than two unhappy tires.
Old Nov 14, 2013 | 12:05 PM
v10climber's Avatar
v10climber
FWD cars on stock suspension lift tires. It's just a fact of life.
The car that won GS this year at SCCA Solo Nationals.
Lots of RWD cars that generate lots of grip will lift the front tire on corner exit.
My wife driving a BSP car.
With modern tires and suspensions some cars are generating so much grip they are getting up on two wheels. DSP is getting to that point.
Old Nov 17, 2013 | 06:31 AM
honda93's Avatar
honda93
That BMW looks familiar... DC Region?
Old Nov 17, 2013 | 01:13 PM
v10climber's Avatar
v10climber
Yep. Lee piccone's car
Old Nov 23, 2013 | 02:02 PM
Christopher Pflaum
I appreciate the feedback and I think I got my answer. thank you.
eatsleepautox
Oct 30, 2015 06:46 AM
theblackfalcon
Oct 11, 2015 09:49 AM
Powershift
Aug 16, 2015 05:14 PM
ki7hy
Aug 12, 2015 07:07 PM
PatrikKN
Aug 5, 2015 09:10 PM
