R56 start up after refuel......
Old Nov 8, 2013 | 12:47 PM
Englaish Matt's Avatar
Englaish Matt
Hello everyone, Newbie here. I just got a 2008 Cooper S for my daily 100 mile commute. Its a pretty high mileage car, but I LOVE it!!
Runs great, but a couple of things I wanted to get advice on.
1) I drive through the Bronx, NY everyday - lots of potholes, when I go over a bump or repaired strip, if I'm accelerating the car seems to jump a bit to one side or other (depending on camber etc) is it normal? and can it be cured or minimized?
2) When I fill the car - (I'm using 89 Oct is that correct?) and go to start it, it almost seems like it wont fire, then stumbles a bit and fires right up.
its the only time this happens, never happens any other start.... any advice or thoughts?
Thanks,
Matt
Old Nov 8, 2013 | 01:40 PM
babysarah's Avatar
babysarah
Originally Posted by Englaish Matt
Hello everyone, Newbie here. I just got a 2008 Cooper S for my daily 100 mile commute. Its a pretty high mileage car ..
.. if I'm accelerating the car seems to jump a bit to one side or other (depending on camber etc) is it normal? and can it be cured or minimized?
2) When I fill the car - (I'm using 89 Oct is that correct?) ..
Thanks,
Matt
Congrats on joining the MINI world. First and foremost, I hope you researched the R56 S before making your purchase. With that being said, I wish you the best of luck in owning a high mileage MINI S with such a long daily commute.
I had an Acura TSX before this car and it had the exact same "jumping around" feeling that you describe. It felt much better after I got an alignment and wheel balance, but it still wasn't 100%. Start with the easiest things first - wheel alignment and balance. After that, it could be several difference things - struts, springs, lower ball joints, tie rod.
As for the gas, you absolutely MUST MUST MUST use a premium fuel!!!
I just had to pick up my jaw off the ground when I read you've been using standard 89 octane fuel. Holy moly.
FUEL MATTERS! I am picky about my gas, and I only use Chevron. If no Chevron, then Shell or BP. Fill up with 91 or 93 next time around and see what happens. Hopefully it resolves the issue, and the hesitation was just your MINI yelling at you for giving it terrible gas.
You may also be interested in checking out these threads for common issues on the R56 Cooper S.
Carbon Build-up
Timing Chain/Tensioner Campaign
Turbo Heat Shield Recall
.. and all of the Stock Problems/Issues Forum
Old Nov 8, 2013 | 02:11 PM
DTH2CHRM's Avatar
DTH2CHRM
Just to piggyback (I agree with everything you said), in our area (I'm in Manhattan), 91 Octane is usually the highest you'll find. Only a few have 93. I wish 93 were more readily available...it would allow for a more aggressive tune.
And to Englaish Matt, congrats and don't forget to wave....especially to me because we're neighbors
As for the gas, you absolutely MUST MUST MUST use 93 octane!!!
FUEL MATTERS! I am picky about my gas, and I only use Chevron. If no Chevron, then Shell or BP. No matter what, always a 93 octane. Fill up with 93 next time around and see what happens. Hopefully it resolves the issue, and the hesitation was just your MINI yelling at you for giving it terrible gas.
Carbon Build-up
Old Nov 8, 2013 | 04:08 PM
Systemlord's Avatar
Systemlord
Great timing because the most notorious issues 2007+ MCS have is the timing chain components, Mini USA is taking care of anyone who has the startup rattling mostly heard the first few seconds and thereafter sometimes lasting indefinitely. Expect to pay for a carbon blasting every 35-50k miles, it's braces of the direct injection. The intake valves never see any of that fuel cleaning chemicals. You don't have to go to the dealer to do it, dealer charges way too much!
Happy motoring.
Old Nov 8, 2013 | 08:09 PM
Fly'n Brick's Avatar
Fly'n Brick
+1 on the 91 to 93 octane. You will, or should, see an improvement in mileage. As for the potholes, go to Way Motor Works (vendor directory) for a pair of M7 strut tower plates. They are a simple 10 minute install. The retaining nuts do need torqued, BTW.
Old Nov 9, 2013 | 06:05 AM
Mannylove's Avatar
Mannylove
Welcome
Welcome to NAM!
This community is no joke....seems like you picked up the car before joining, which is probably what most do. Never fret, you're in good hands...
If you see me cruising down the Hutch, wave at me too.
"Let's Motor"
Old Nov 9, 2013 | 09:44 AM
Systemlord's Avatar
Systemlord
Is there a fuel additive to increase the octane rating that is safe for those without access to anything higher than 91 octane?
Old Nov 9, 2013 | 10:03 AM
babysarah's Avatar
babysarah
To my knowledge, they don't seem to be worth it. From what I understand, they only bring your octane up about 4-5 points .. so 0.??? something. Not enough, in my opinion, to see a big difference. I used to use one every fill up on my Cobra that I had years ago, never really saw a difference so that was the end of so-called "boosters."
Old Nov 9, 2013 | 03:51 PM
Fly'n Brick
91 is all that's available around here. Once in a while we find ourselves in 93 octane land and I do notice a small difference mainly in the OBC estimate on fuel range maybe a little higher. 91 is just fine.
Just make sure you are getting it from one of the 'Top Tier' vendors.
http://www.toptiergas.com/retailers.html
Old Nov 9, 2013 | 10:08 PM
Gubi's Avatar
Gubi
On my R56 the octane requirement in the filler cap is 89. So even midgrade should be fine for the N18, not sure if the earlier engines were different. You're not hurting anything if you go with 93, but probably not helping anything either.
Damn near all modern cars (I assume the Mini included) have a knock sensor. So even if you go too low on fuel octane it won't damage anything, you'll just lose a little power because the car will retard the timing.
Pour in octane boosters are absolutely not worth it. The "points" they refer to on the bottle are tenths of an octane number, so "raises octane by up to five points!" equates to 0.5 octane. Big whoop. Also some of them contain manganese compounds (the less toxic modern equivalent of tetraethyl lead) which isn't good for your spark plugs or cat converter.
TLDR: just go with the manufacturer's listed octane or higher and you'll be fine.
(For the record, I'm a Chem E and worked in the refining industry for a few years.)
Old Nov 10, 2013 | 12:37 PM
Englaish Matt
Thanks so much everyone for the feed back! I do cruise along the Hutch! I travel every day from SW Fairfield county (Weston)on the Merritt Parkway, Hutch Or Cross Bronx Expressway to the south Bronx. With some of the potholes, its like getting hit with an IED ! I love this car, I'm going to start a blog, Just getting back on my feet after losing my job earlier this year, and I am going slowly and carefully. got the car for a fantastic price, Just got a K&N Typhoon kit for $175, so it going to be my low budget buzbomb! His name is Jarvis, silver with a black roof ( just like my hair) and an incredibly well looked after red leather interior. I'll post some pics soon.
Matt
Old Nov 10, 2013 | 05:09 PM
babysarah's Avatar
babysarah
Originally Posted by Gubi
On my R56 the octane requirement in the filler cap is 89. So even midgrade should be fine for the N18, not sure if the earlier engines were different. You're not hurting anything if you go with 93, but probably not helping anything either ...
On my 07 MCS, the minimum recommended octane rating is 91 as per the owners manual. Where I live, we don't have too many places with 91, so 93 is my minimum. Although the minimum is 91, even my service advisor says it is best to use 93 when possible. The OP has an 08, so his recommended octane levels will be the same as mine. For me, I can feel a difference in start up if I use bad quality gas or lower-than-recommended octane. So, I avoid it at all costs.
For your '12 MCS, your owners manual says that 91 is the "highly recommended" minimum octane. 89 is simply the minimum usable octane. There is a huge difference. As per your manual ..
The minimum AKI Rating is:
- Cooper S: 91 John Cooper Works: 93
- Cooper: 89
Old Nov 10, 2013 | 05:42 PM
Gubi's Avatar
Gubi
Yep, you're correct, Sarah: N18 manual says 91 is "highly recommended", didn't see that. However, right below that the minimum required for '12 Cooper S/JCW is listed as 89, not 91/93, and that's what it says on the fuel lid.
Those words have specific meaning with regards to octane. "Recommended" means you can run lower without damage, but may lose a bit of power due to the retarded timing. If the manual says "required" there is the risk of engine damage. So just keep it above the minimum and nothing will a'splode.
Anyway, my point was that saying you "must must must run 93" is incorrect, so don't scare the kid. No car sold in the US requires 93, because 93 isn't available everywhere (max in CA is pretty much 91). Go by what the manual says and you'll be fine.
Old Nov 10, 2013 | 07:07 PM
Systemlord's Avatar
Systemlord
Do 2007 MCS have a knock sensor? I've seen an area in the head near the dipstick that's drilled out expect instead there's just a hole with nothing in it. I've seen in the newer models there's something screwed in that looks like a O2 sensor, is this the knock sensor? Every now and again I'm getting a persistent periodic ping/knock, my gas tank fuel pump is getting louder.
Attached Thumbnails start up after refuel......-img_0791.jpg   start up after refuel......-img_0796.jpg
Old Nov 10, 2013 | 07:22 PM
Gubi's Avatar
Gubi
Per the Bentley service manual, the R56 knock sensor is "bolted to the rear of the engine block near the starter motor". So yeah, looks like you should have one, just not where you're looking.
Shot in the dark guess on that would be a clogged fuel filter? That would cause the pump to strain and could theoretically cause lean running under load, which could result in detonation. However, one would think that would throw a check engine code.
Really just a guess, though.
Old Nov 10, 2013 | 09:08 PM
Fly'n Brick
You touched upon big pot holes again. Again, don't overlook the front strut tower defenders. WMW carries the M7 models, very easy to install, remove 3 nuts, lay the plate in place and replace the nuts, torque to 25#.
Old Nov 10, 2013 | 09:16 PM
Gubi's Avatar
Gubi
Is the strut tower mushrooming still a problem for the R56? I haven't gotten the tower defenders because I thought that was fixed. But if it's still an issue...
Old Nov 10, 2013 | 10:54 PM
Systemlord's Avatar
Systemlord
These fuel filters are good for 100k, I hear that they are huge in size. Interesting is my in-tank fuel pump is starting to whine a bit more than usual, like a harmonic high frequency whistle. Can these fuel filters be accessed via underneath the rear seats or do I have to drop the gas tank?
Old Nov 11, 2013 | 07:58 AM
babysarah's Avatar
babysarah
.. my point was that saying you "must must must run 93" is incorrect, so don't scare the kid. No car sold in the US requires 93, because 93 isn't available everywhere (max in CA is pretty much 91). Go by what the manual says and you'll be fine.
Touche. I forgot that a lot of states don't have access to 93 as much as they do 91. Finding 91 is rare here in Florida, so when my cars say "use premium" I automatically think of 93. Except Wawa, they have 92.
Old Nov 11, 2013 | 09:01 AM
AZdsrt's Avatar
AZdsrt
A week or so ago I read a long thread with pics how to change out the fuel filter. It didn't look too hard, and yes you can access it from under the rear seat.
Old Nov 11, 2013 | 09:21 AM
drachen's Avatar
drachen
Torque steer might partially be to blame here, also what is the configuration of your tires? If you mix and match the original run flats with non run flats this can happen too.
You should use 91+ and avoid lower octane stuff if at all possible. In an emergency, 87/89 can be used and the engine should in theory pull timing to prevent damage. By using 89 or lower octane you are losing combustion efficiency to the point that the few pennies you save between 89/91 is just not worth it.
Old Nov 11, 2013 | 11:35 AM
Systemlord's Avatar
Systemlord
Do you remember where this thread was located? On NAM?
Old Nov 12, 2013 | 05:45 PM
AZdsrt's Avatar
AZdsrt
The thread is here -
https://www.northamericanmotoring.co...er-change.html
The DIY with pics is here -
http://www.minicooperspeed.com/fuel-filter-change/
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
LordOfTheFlies
Oct 19, 2015 05:02 PM
Steffen.Johnson
Aug 23, 2015 08:30 PM
