R56 MCS being a pain after clutch replacement. need help**
Old Oct 4, 2013 | 04:23 PM
ms.mini's Avatar
ms.mini
Ok, so I'm going to be using my girl's account to post this, as there is no point for a middleman. She bought a 2010 mini cooper s and the clutch went out (pressure plate). Anyway I replaced it with a new OEM clutch kit (disc, pressure plate, throw out bearing ect), and everything seemed to be perfect. Two days went by and now it has a check engine light on along with the abs, traction control lights. Is there some type of reset that needs to be done? The battery was unplugged for the entire time it took to replace the clutch.
Then going back over everything I found this plug hanging out next to the fuse box under the hood. Any ideas what it is/goes to?
Old Oct 4, 2013 | 04:32 PM
ms.mini's Avatar
ms.mini
Old Oct 4, 2013 | 04:35 PM
Systemlord's Avatar
Systemlord
I'm getting my Mini back in about an hour, I'll check for you. I believe it connects to the master cylinder under the main fuse box or near it, but not 100 percent sure. It's time to clean your engine bay, your Mini would appreciated it.
Old Oct 4, 2013 | 04:38 PM
ms.mini's Avatar
ms.mini
Lol yeah, full detail is happening right after alignment.
thanks man, I appreciate it.
Old Oct 4, 2013 | 05:49 PM
Melangell's Avatar
Melangell
Frack the BS of cleaning your engine bay!!! Take it back to the person who did the work. You actually waited to post here????
Old Oct 4, 2013 | 06:06 PM
ms.mini's Avatar
ms.mini
The owner is my girlfriend, I did the work. I'm trying to get some help on trouble shooting.
Any who, I ran the CEL and it's saying the vehicle speed sensor. But the VSS is working??
Old Oct 4, 2013 | 06:11 PM
Melangell's Avatar
Melangell
Wasn't for the op... T/was to the was the engine bay guy. Dude, if you did the work and it didn't work and you aren't a Mini specialist... bring it to one. NOT to a dealer... charge way too much. In Savannah, let me know. I know someone to help. Near Atlanta. take it to Way.
Old Oct 4, 2013 | 08:47 PM
ms.mini's Avatar
ms.mini
Lol, maybe you didn't read the original post. Everything was working flawlessly, these cars really aren't that hard to work on.
Dug back into it today, found out why the abs/trac lights came on... Wheel was rubbing up against wire :(
Nothing a simple solder job couldn't fix, but the lights are still on. So can anyone tell me if I have to reset the brakes and/or how?
Old Oct 4, 2013 | 08:49 PM
Melangell's Avatar
Melangell
Just trying to help....
Old Oct 4, 2013 | 09:07 PM
ms.mini's Avatar
ms.mini
Thanks, I appreciate it..
Man, I dug under there and didn't seem to find anything. I do remember it being clipped on the side of the fuse box though, just can't remember if anything plugged into it.
Old Oct 4, 2013 | 09:43 PM
Systemlord's Avatar
Systemlord
Alright it connects to the front of the fuse box housing, look straight down in the front of fuse box.
Old Oct 4, 2013 | 09:48 PM
Systemlord's Avatar
Systemlord
Old Oct 4, 2013 | 09:58 PM
Systemlord's Avatar
Systemlord
Chill, no need for personal attacks. Try to keep the drama out of your posts if you could please.
Old Oct 4, 2013 | 10:43 PM
ms.mini's Avatar
ms.mini
So it definitely connects to another wire huh.. hmm, is there any way I can bother you for a picture?
Old Oct 4, 2013 | 11:58 PM
Systemlord's Avatar
Systemlord
Here it is ->
Attached Thumbnails MCS being a pain after clutch replacement.  need help**-img_0597.jpg   MCS being a pain after clutch replacement.  need help**-img_0596.jpg   MCS being a pain after clutch replacement.  need help**-img_0595.jpg
Old Oct 5, 2013 | 04:55 AM
v10climber's Avatar
v10climber
I looked for the other end of that damn wire for 6 hours when I did the diff install. Apparently on some cars its connected and some it isn't. You can search my posts to find my thread on it. If you don't have anything to plug into it don't sweat. Must be for an option we don't have.
Sent from my DROID RAZR HD using NAMotoring
Old Oct 9, 2013 | 07:22 PM
ms.mini's Avatar
ms.mini
Well just for the update, everything is back to normal. Not sure exactly what happen, everything was just off one morning when I went to move it out.
Markbett
Jul 3, 2016 04:28 PM
Camaro108
Aug 25, 2015 02:44 PM
DiGiPiMP
Aug 24, 2015 11:04 AM
PrimePower
Aug 16, 2015 06:29 PM
minipopkart
Aug 13, 2015 05:22 AM
