R58 S Coupe - Sport Mode
Old Jun 7, 2013 | 07:59 PM
S Coupe 2013's Avatar
S Coupe 2013
Is there any way to program the sport mode to come on automatically instead of having to push the button each time I start the car.
Also, has any one added the Sport Driving Lights addition mod. Does it increase night time visibility?
Thank you for any insight that you can give me.
Rick
2013 S Coupe - Three weeks old.
Old Jun 7, 2013 | 08:35 PM
greenminiclub's Avatar
greenminiclub
Waymotorworks carries a box you can wire in that will automatically recall the last sport mode setting. You can also use it to program an auxiliary function as well.
Old Jun 7, 2013 | 09:44 PM
Naylia's Avatar
Naylia
Here in CA, driving lights can only be used when using high beams - but during those times if I have remembered to take the covers off they do increase visibility.
Old Jun 12, 2013 | 06:27 AM
TheGeekGuy's Avatar
TheGeekGuy
I never understand what is so difficult about reaching down and pushing a button? I do it every time I get in the car. Saves money and is frankly very, very easy.
Old Jun 12, 2013 | 07:13 AM
jcauseyfd's Avatar
jcauseyfd
The remembering to do it part.
Old Jun 15, 2013 | 02:40 PM
OaklandMini's Avatar
OaklandMini
But you'll know instantly if you haven't pushed it when you nearly clonk out at a red light whe you shift into first.
Old Jun 16, 2013 | 08:19 AM
wilpower's Avatar
wilpower
The position of the sports button has been a pet peev with me, Im sure they could have made the button flush and put it on the steering wheel or better still the gear ****....Just sayin.
Old Jun 16, 2013 | 11:11 AM
Soulmaker1's Avatar
Soulmaker1
+1, a retro dial that can be set, like on the Ferrari would be cool.
Old Jun 24, 2013 | 12:32 PM
TheBigNewt's Avatar
TheBigNewt
Yeah I wish you set it to come on automatically. I remember some workaround thingy that some have used. I tend to stall out if I don't use it. It's more the throttle than the steering for me.
Old Jun 24, 2013 | 06:57 PM
Deli's Avatar
Deli
Speaking of sport mode, is there a difference in gas mileage for driving using the sport mode?
Old Jun 25, 2013 | 04:25 AM
jcauseyfd's Avatar
jcauseyfd
If you have an automatic it will due to the change in shift points.
All of the newer models should see a slight decrease in efficiency from Sport mode due to the extra fuel used to create the pop & burble effect. I suspect that is small enough to not have a measurable impact.
Old Jun 25, 2013 | 04:30 AM
SuperGreg's Avatar
SuperGreg
Here's the deal. The best mpg is achieved when shifting around 2,000-2,500 rpm. That's almost impossible to do while in Sport mode because the throttle response is so much quicker. You will be at 3,500 rpm+ in the blink of an eye, and therefore get worse mpg. But the fun factor is worth it!!
Old Jun 25, 2013 | 04:36 AM
yetti96's Avatar
yetti96
It depends on how you drive the car but it won't inherently just use more fuel. In an automatic, probably a little worse MPG because it leave the revs higher. I consider my car the best in economy; smiles per gallon is very high. It's more important than mpg
Old Jun 25, 2013 | 04:57 PM
Deli's Avatar
Deli
Thanks for the replies; I've got a manual transmission.
ahmedalsurmi
Sep 25, 2023 04:49 AM
Sep 14, 2015 12:48 PM
HogWldFLTR
Sep 8, 2015 05:25 AM
Sailorlite
Sep 4, 2015 07:03 PM
