R56 Boost Cuts Out
Old May 21, 2013 | 08:28 PM
MuR56phy's Avatar
MuR56phy
Boost Cuts Out
2009 Mini Cooper S. In 4th, 5th and 6th gear my boost cuts out at 3500, 3000, 3000 rpm respectively. Highway pulls are impossible. I've got a handful of mods, it's been tuned and tested for boost leaks and everything checks out. Anyone else notice something similar or know a way to fix it? As always, your help is much appreciated!
Old May 22, 2013 | 11:19 AM
Kalibdor's Avatar
Kalibdor
Any CEL's? Hard to tell without a code. Are you getting the yellow half engine power symbol on the tach?
Old May 22, 2013 | 01:17 PM
MuR56phy's Avatar
MuR56phy
I'm not getting a CEL but my AccessPort is showing a couple codes. The only two that have a description are front o2 check min, and int manifold leak, not sure what to think about either one
Old May 22, 2013 | 01:19 PM
ThumperMCS's Avatar
ThumperMCS
Intake manifold leak will cause boost issues for sure...
Old May 22, 2013 | 02:05 PM
MuR56phy's Avatar
MuR56phy
The codes are:
P2096
P1497
P2AC2- front o2 check min
P2B64- int manifold leak error
Old May 22, 2013 | 02:11 PM
ThumperMCS's Avatar
ThumperMCS
The codes are:
P2096
P1497
P1497 is your problem...
Check again for leaks...and also check the inlet piping into the turbo...they tend to split and this will cause a vaccuum leak
Your car is boost cutting because it is trying to hit certain boost target but it isn't reaching them so it just trys to run more boost to compensate and it will only run so much before it cuts out like you are seeing.
Old Feb 21, 2014 | 10:49 PM
Sean Sykes's Avatar
Sean Sykes
Turbo Inlet Sugestions and intake tubing
Hello to you all,
I am new to this forum and have to say that all of your feedback has helped me tremendously. I have owned for a year a 2009 factory JCW with a DOS CAI and DOS WTAIC running Alta Stage 1. I have been experiencing boost cutting recently and after further investigating my turbo inlet is warped on the turbo housing and needs to be replaced. I want to go with an aluminum upgrade possibly the Alta but wanted to see if anybody else recommended another vendor with a more durable approach. I also have to replace my intake tubing from the hood to the lower intake because of warping on the tube. Does anybody know of a more durable non plastic replacement for this? I can only find the cheap plastic stock version which is beyond me why Mini decided to go with so much plastic throughout the intake system.
Old Feb 24, 2014 | 06:55 AM
bmx045's Avatar
bmx045
Originally Posted by Sean Sykes
Hello to you all,
pretty positive nm engineering makes an aluminum one
ahorvath
Oct 3, 2015 01:13 AM
Oct 1, 2015 12:13 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
BossyR56
Sep 28, 2015 11:33 AM
EVMini
Sep 28, 2015 10:20 AM
