R50/53 radiators fans fuse
Old May 14, 2013 | 12:57 PM
hellomoto's Avatar
hellomoto
radiators fans fuse
hello peoples,
i finish resistor fix on radiators fans and aircon working now - thank you everybody to help find and write fix! my radiators fans fuse 5A keep blows when aircon on 3 minute. i check powers steering fans turning okay and no garbages to grill. i see radiators fans turning and stop immediately because 5A fuse is blows. i read on outside northamericanmotoring.com website sayings radiators fans fuse is incorrect label of 5A. they says stealer mechanic says 15A on 9 blades radiators fans is correct and 5A on 7 blades radiators fans. is stealer mechanic says okay? i count my radiators fans of 9 blades. i drive high speeds and fuse not blows - stage 2 radiators fans speeds. only low speeds fuse blows - stage 1 radiator fans speeds. please help to know what is correct fuse because blows every time aircon. thank you peoples for help me. God bless to peoples!
Old May 14, 2013 | 03:45 PM
Braminator's Avatar
Braminator
Here are all fuses and relays etc..
Engine compartment fusebox
F1 5A Digital engine electronics control unit
F2 20A Digital engine electronics control unit/Ignition coil/Cylinder 1-4 fuel injection valves/Crankshaft position sensor (From K6300 87)
F3 15A Camshaft position sensor/O2 sensor before cat/O2 sensor after cat/Solenoid valve, fuel tank ventilation/Relay K19 control power (From K6300 87)
F4 15A Tank Leakage diagnosis pump
F5 5A Relay, engine cooling electric fan (From K6300 87)
F6 30A ABS/ASC/DSC control module
F7 30A Magnetic clutch for AC compressor via relay K19
F8 30A control power K69923 Relay, electric power steering pump cooling fan/Switch unit Heating & A/C blower
F9 20A BC1 (X11177 2) unit via I01136 and I01137 (Relay front wiper motor fast/slow and Relay front wiper motor on/off)
F10 15A BC1/Left fog/Right fog/Switch panel via K47
FL1 50A Feed to F14, F31, F32 (BC1,Heating & Air con blower, cigarette lighter)
FL2 50A Feed to F1, F2, F3, F4, F19, F20, F21, F22, F23, F24, F25, F26, F27, F28, F37 (BC1, steering angle sensor, clock, instrument cluster, navigation, on-board monitor, wash/wipe, horn, audio system.)
FL3 40 A Convertible top control
FL4 100A Electric Steering control unit/Hydraulic pump
FL5 50A Feed to F15, F16, F17 (Sunroof, aerial antenna, rear wiper)
FL6 40A ABS/ASC/DSC unit
FL7 50A Feed to ignition switch
FL8 50A BC1 (X332 20) Headlight
FL9 50A DME unit and Switching unit 2-speed blower via I01135 (Relay electric engine cooling fan)
FL10 50A K416, Relay heated front screen
FL11 50A Switch unit, 2-speed blower heating & air con
FL12 50A BC1 (X332 17) Headlight
F01 5A Engine Control Module (ECM), Convertible top control Module
F02 20A ECM, ignition coil, fuel injectors, crank position sensor
F03 15A Engine control
F04 15A Engine control
F05 5A Engine cooling fan
F06 30A ABS/ASC/DSC
F07 30A Air Con compressor
F08 30A Heating A/C blower, EHPS cooling fan
F09 20A Windscreen wipers
F010 15A Parking lights
(Sometimes F0 fuses above are labeled F only in Eng. Comp. Fusebox)
Passenger compartment fusebox
F1 30A BC1 (X332 3) power windows LH
F2 5A Steering angle sensor
F3 5A Digital clock/Outside mirror fold-in control unit
F4 5A BC1 (X254 27) Constant power
F5 5A Control module for instrument cluster/Diode (From Electronic immoblizer control unit)
F6 5A Brake light switch/Clutch switch module/Electronic immobilizer control unit EWS
F7 5A BC1 (X254 36)/Rain sensor
F8 5A Turn indicator/low beam switch
F9 5A Control module for instrument cluster
F10 5A Navigation computer/On-board monitor control unit/Radio control unit
F11 5A K119, Relay, rear washer pump/K5 Relay, front washer pump
F12 20A Ignition switch to heated seats
F13 5A Reversing light switch/CVT switch
F14 10A BC1 (X332 14) Constant power to interior/reading lamps
F15 20A Sunroof module control unit
F16 30A BC1/Rear window w/o antenna or Wave trap 1 w/ rear window antenna via K13/ Heated rear screen
F17 15A BC1 (X254 43)/Rear window wiper motor via I01142 (Relay rear wiper motor)
F18 5A Hall sensor driver & passenger buckle/Multiple restraint system (MRS system)
F19 30A BC1 (X332 7) power windows RH
F20 20A K96, Fuel pump relay 1
F21 10A Control module for instrument cluster
F22 15A On board monitor control unit/Navigation computer/Eject box
F23 20A K5 Relay front washer pump/K119 relay rear washer pump
F24 5A Electronic immobilizer control unit/Horn for antitheft alarm system EWS
F25 30A Headlight washer pump via K6
F26 10A Automatic transmission
F27 15A Radio control unit/CD Changer/Amplifier
F28 15A Volute spring/Right horn/Left horn via K2
F29 5A Heating and AC control module/Sensor interior temperature fan
F30 5A Instrument cluster
F31 30A BC1 via K4 (X253 23) Heating & A/C blower
F32 15A Front cigar lighter via I01151 (Relay cigarette lighter front)
F33 10A ABS/ASC/DSC unit
F34 10A Digital engine electronics control unit direct and via K96/Eng management main relay
F35 5A Mirror adjustment switch/Electrochrome rear view mirror/Windscreen washer jet heater/Outside mirrors
F36 5A K416, Relay Heated front screen
F37 20A BC1 (X332 1) Central locking
F38 -
F39 5A Alternator/Electric Steering control unit/hydraulic pump
F40 5A Control module for instrument panel/Switch panel/Steering angle sensor
F41 5A Park distance control unit/power to K69923, Relay fan steering control module/pump
F42 -
(MCS Only - Luggage compartment fusebox, MC/One direct battery feed)
F100 250A Feed to FL1, FL2, FL4, FL5, FL6, FL7, FL8, FL9, FL10, FL11, FL12, F1, F6, F7, F8, F9, F10, K6300
For Ref.
BC1 (Body Control Unit)
Located behind kick panel - drivers footwell (UK) / passengers footwell (USA / Europe)
4 Connectors:-
X332 20 pin (green)
X253 54 pin (black)
X254 54 pin (natural)
X255 54 pin (blue)
IDs for Relays / Location
K42 Horn relay / Behind Passenger compartment fusebox
K4 Heater-blower relay (up to March 2003) / Engine compartment fusebox
K4 Heater-blower relay (from March 2003) / Passenger compartment fusebox
Control: BC1 (X253 23)
Switch: M30/A11
K5 Relay washer pump front / Behind passenger compartment fuse panel
K6 Relay Headlight washer / Passenger compartment fusebox
K13 Relay rear window defroster / Behind Passenger compartment fuse panel
Control: BC1 (X254 22)
Switch: Rear window defroster
K19 Relay AC Compressor / Engine compartment fusebox
K47 Front fog light relay / Engine compartment fusebox
Control: BC1 (X254 40)
Switch: Left fog light/Right fog light/Switch panel light
K96 Fuel pump relay / Passenger compartment fusebox
Control: A6000 (X60004 24)
Switch: M2
K104 Relay auxiliary water pump
K119 Relay washer pump rear / Behind passenger compartment fuse panel
K416 Relay heated windshield
K6300 DME Main Relay / Engine compartment fusebox
control: A6000 (X60004 16)
Switch: F02/F03/F04/F05
K69923 Relay EHPS fan power steering / Behind passenger compartment fuse panel
I01135 Relay Engine cooling fan stage 2 (from March 2003) / Engine compartment fusebox
I01136 Relay front wiper fast/slow / Engine compartment fusebox
I01137 Relay front wiper on/off / Engine compartment fusebox
I01142 Relay rear wiper / Behind Passenger compartment fusebox
I01148 Relay Shiftlock / Passenger compartment fusebox
I01151 Relay front cigarette lighter / Behind Passenger compartment fusebox
I01152 Relay Engine cooling fan stage 1 / Engine compartment fusebox
Body Earth Locations
E1 LH rear of engine compartment
E2 LH front of engine compartment
E3 RH front of engine compartment
E4 RH side of footwell
E5 LH door sill
E6 LH side of luggage compartment
E7 RH side of luggage compartment
E8 RH door sill
E9 LH door sill
E10 Behind LH rear window trim panel
E11 Behind RH rear window trim panel
Old May 15, 2013 | 06:15 AM
hellomoto's Avatar
hellomoto
i refer to F5 5A Relay, engine cooling electric fan (From K6300 87). this is outside websites says 15A fuse to 9 blade radiators fans.
http://www.mini2.com/forum/archive/i...p/t-11922.html
did they says correct?
Old Nov 13, 2013 | 07:22 AM
eciaccord's Avatar
eciaccord
Thank you Braminator for the detailed list above.
I was hoping someone could please help with an issue I am currently dealing with my daughter's 2009 Mini Cooper Hatchback Base. About a week ago my wife and I were driving the Mini and it showed no signs of an electrical issue. We parked the car in the driveway and it sat overnight. The following morning, my daughter got in the vehicle, placed the key in the ignition when suddenly the lights flickered on the dash and then turned off. The brake pedal had been depressed and now feels very stiff. She attempted to start the car again but it has absolutelty no power to the engine. I tried jump starting the car and still had no luck getting the car to power up. I removed the battery and checked the terminals along with the ground and there is no corossion on either. I took the battery to auto zone to have it checked and was told the battery was not holding a charge. I bought a new battery, installed it and still have no power to the engine. Now, all the lights come on inside the vehicle but I still have no power to the engine. I then tested the fuses in the engine block using a one of those bulb power probes and discovered F2 fuse (light is dim), F3, F4, and F5 fuse have no power. I checked the fuses and they all appear fine but when I took them out there is still no power to those fuses. I then checked the fuses in the passenger compartment floorboard and noticed fuse F44 has no power and F31, F32,F33, F34, and F35 have no power either. I went as far as changing the fuses underneath the fuse block in the engine bay (the FL1 60amp and FL2 80amp). Is there something that I am missing that feeds power to these fuses. I have racked my brain trying to find a solution aand have had no luck with the limited tools that I have. I am trying to avoid taking it to the dealer when I am missing something that is an easy fix.
PsychoRallye
21
Feb 17, 2019 06:08 AM
mni928
Nov 9, 2015 07:38 PM
JAB 67
Sep 29, 2015 01:34 PM
rt808
Sep 25, 2015 01:59 PM
