R50/53 Which boost gauge do we use
Old Apr 24, 2013 | 06:26 PM
R53minime's Avatar
R53minime
Can we use a electronic boost gauge or do I need to order a mechanical boost gauge?
Old Apr 24, 2013 | 06:39 PM
Braminator's Avatar
Braminator
Just get a ScangaugeII unless you like the looks of the round gauges.
Old Apr 24, 2013 | 06:41 PM
R53minime's Avatar
R53minime
Ya I like the look I the round gauges
Old Apr 24, 2013 | 07:48 PM
Da_Ghost's Avatar
Da_Ghost
You can use both, depends on the gauge you want. I have a Prosport electrical and I like it.
Old Apr 24, 2013 | 10:09 PM
Melangell's Avatar
Melangell
I'm a simple (old) man wanting a round gauge with an arm that moves. Question a little off topic... just a little. I will get a Prosport boost gauge. In addition I want either an oil temp or (more so) an oil pressure gauge. Which is an easier install. I'm asking because I've gotten the idea that one is easier than the other on the N18 and I'm not sure which and I've yet to have time to read the threads to figure it out. Wow, that last sentence sucked... bourbon....
Old Apr 24, 2013 | 11:25 PM
Kahnfucious's Avatar
Kahnfucious
Braminator do you happen to have the instructions on how to program the scangauge for boost on the r53?
Old Apr 25, 2013 | 01:56 PM
nicefighter80's Avatar
nicefighter80
Yea you save ~$80 and just buy the ultragauge It has a boost reading in it already http://www.ultra-gauge.com/ultragauge/index.htm
Old Apr 25, 2013 | 02:05 PM
Kahnfucious
[URL="http://www.*********************/forums/cooper-s/2895-scan-gauge-ii-help-3.html#axzz2RVkqOZ00"]
Ha -- thanks NiceFighter -- I found this... will try later.
Old Apr 25, 2013 | 02:50 PM
nicefighter80
You saw this one right? https://www.northamericanmotoring.com/forums/how-to/128221-electrical-displaying-boost-on-a-scangaugeii.html
Old Apr 25, 2013 | 03:00 PM
Kahnfucious
Yes sir -- thanks...I will report back later tonight with results -- hopefully good ones.
Old Apr 25, 2013 | 07:28 PM
Kahnfucious
Okay so I followed the instructions in that post and it worked if its accurate.
I have a 15% craven speed pulley. If i rip on the car I see 13.5 psi of boost.
Sitting at idle I see -8.2 -> -8.5
Does that make sense to guys on the board?
Doc Pain
Oct 28, 2015 07:09 PM
Oct 1, 2015 12:13 PM
papawhiskey
Sep 30, 2015 02:50 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
