R50/53 Whats the best CAI for R53
I don't think anybody's done side by side tests. Everybody will tell you theirs is the best, of course, so I'll start: our is the best
Choose the one with the type of filter that you like: typically aftermarket ones are foam or cloth based. I like cloth better because it lasts longer and doesn't leak heavy oil into the motor and intake bottom.
. Choose the one with the type of filter that you like: typically aftermarket ones are foam or cloth based. I like cloth better because it lasts longer and doesn't leak heavy oil into the motor and intake bottom.
This question has been asked a thousand times. 'Best' is subjective. Best sound? Best flow? Best cost? Best visually? Best value?
We can't offer an opinion as to what would be 'best' for you without knowing what your priorities are. The JCW is the most expensive, and has the (IMO) cool 'flap' feature that reduces noise until you hit 4500RPM. Dinan and JCW look most OEM. The 'HAI' (a K&N stuck onto the throttle body) is the simplest and cheapest. DDM, Alta, ProMINI, MiniMadness, they all perform at a similar level (IMO) with different looks.
My suggestion - do a search on CAI, and see what everyone has to say.
Dinan or JCW!
The Dinan is now discontinued, but if you can find one it is well worth it. It is well built and flows well without interfering with any other mods you might add.
I own a K&N Typhoon which is a cloth filter. Gives me alot of noise on the highway with the whistling. Definitely one of the louder intakes on the market. Best part is the look of it though. If you don't mind a bit of whistling, then it'll be worth it.
I've had the best luck with the DDMworks intake, and use it on my personal car. If you're trying to measure HP difference in intakes you're going to be splitting hairs. Go with the DDM it fits right, won't rust, makes great power, and sounds great.
There would probably be no measurable difference in performance or durability between the Helix and the DDM intakes. They're both excellent.
tr3y003
33
Jun 5, 2020 05:00 AM
VanisleRyan
26
Sep 15, 2015 06:19 AM
