Need alternative size for 175/50R13?
Old Apr 17, 2013 | 12:00 AM
lazykenji's Avatar
lazykenji
Hi all, anyone know what i can put on my Mini Clubman GT instead of 175/50R13, this size is discountinued and I need to replace all 4 now due to crack, any other choice instead of paying the crazy $600 to get it ship from UK.
Old Apr 17, 2013 | 02:56 AM
Clubman S's Avatar
Clubman S
Hi, check if you have locally available 195/45R13 this tire works well on Supalites 13x7" wheels
cheers
Axel
Old Apr 17, 2013 | 09:02 AM
lazykenji's Avatar
lazykenji
No luck on the 195/45R13 either, will 195 look too wide?
https://www.dropbox.com/s/d2kfafohes...2008.42.37.jpg
Old Apr 17, 2013 | 04:43 PM
lazykenji's Avatar
lazykenji
I checked around and no one carries 195/45r13 either... but will 195 be too wide?
Old Apr 17, 2013 | 07:57 PM
ZippyNH's Avatar
ZippyNH
BF Goodrich® Euro T/A - 175/50R13 Load Range 76H
Try Sam's wholesale clubs in the US...they list them as a "special order size", but does not show the price...says you must visit the club for the price.
Shipping Included
This product ships to all U.S. SAM'S CLUB locations.
BF Goodrich Euro T/A Performance Tire has Advanced Tread Compounds that assure good wet and dry traction.
Back to top
SPECIFICATIONS
Advanced tread compounds assure good wet and dry traction
Reinforced two-ply polyester carcass construction allows higher inflation pressures for higher load capacity, improved durability and helps provide extra rim protection
New sidewall graphics
H-Speed rated
Back to top
Old Apr 17, 2013 | 08:02 PM
ZippyNH's Avatar
ZippyNH
http://www.minimania.com/part/TYRE18...MINI--COOPER-S
OUCH!!
$175 each!!
then again...these folks tend to be the MOST $$, but if it is the only choice....
But use google....I bet you can find that size somewhere!!
Old Apr 17, 2013 | 08:04 PM
ZippyNH's Avatar
ZippyNH
http://ejelta.com/tiresize/index.htm...size=175/50-13
Look at this chart...will give you ALL the info on alternate sizes you need!
Old Apr 20, 2013 | 06:24 PM
lazykenji's Avatar
lazykenji
Thank you guys for the suggestion.
I have finally found one US website that have them in stock after spending days of searching.
Ive got 4 for a total of $455.83 shipped to Los Angeles, cheapest I could found.
Below is the link to the site. This is my first contribution to this site and hopefully can help some of you.
TIRE_BFGOODRICH_EURO TA07_175/50R13
http://autoplicity.com/products/1409...75_50r13_.aspx
Coupon:
30% off Shipping = [FONT=Courier New]30offshipping[/FONT]
[FONT=Courier New]4% off sitewide = fallsavings[/FONT]
[FONT=Courier New]2% off sitewide = 2offap[/FONT]
Note: shipping and discount coupon are stakable.
Old Feb 8, 2014 | 05:56 PM
Le Fraug's Avatar
Le Fraug
here are two tires in 174/50-13 available in the States
Nankang and Dunlop both under $80
http://www2.tires-easy.com/cgi-bin/r...GAN&kategorie=
and another one
Sumitomo
http://simpletire.com/sumitomo-p175-50r13-5515770-tires
Old Feb 14, 2014 | 02:22 PM
Alex@tirerack's Avatar
Alex@tirerack
Way underload
175/50 's are load index 72. This leaves you over 500 lbs less than stock gvaw requirements. Unsafe, IMO.
Old Nov 20, 2017 | 04:25 PM
buckcherry1976's Avatar
buckcherry1976
Tires
Hi i just happen to have a brand new set of tires this size
Doc Pain
Oct 28, 2015 07:09 PM
SJ-R50
Oct 28, 2015 08:39 AM
schr5530
Oct 5, 2015 08:28 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
daviday
Sep 25, 2015 01:31 AM
