R50/53 Zip-tied Shutoff Valve --> Immediately more boost --> threw engine light
Old Mar 25, 2013 | 05:09 PM
Hochspannung's Avatar
Hochspannung
I zip tied my shutoff valve closed just now to see why I was having boost lag. The results were immediate and The supercharger now delivers full boost with no delay. So I have pinpointed that I need a new shutoff valve.
I threw a check engine light after a few minutes of test driving.
If I remove the zip tie, does it go away?
If I keep the zip tie there is that bad in any way?
Old Mar 25, 2013 | 05:22 PM
BlwnAway's Avatar
BlwnAway
Leaving the zip tie on the bypass valve really shouldn't be done, the ECU will prob. see this as a prob. therefore giving you that light, not to mention poorer fuel milage, and the longer you keep it like that, the more compensations the ECU will try & make for it, that will have to then be made again when you fix the problen and everything has to go back to where it is now again.
Drive it w/o the zip tie a few days, if the light doesn't go out on it's own it just may simply have to be cleared, any local Autozone type place can do it for you.
Old Mar 25, 2013 | 05:26 PM
Hochspannung
k thanks sounds good. I'll pull it off. Going to order a DT Bypass valve in the near future.
Etrain
16
Aug 5, 2024 04:37 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
