R50/53 manualy opening doors
Old Mar 18, 2013 | 06:14 PM
GreekDrifter91's Avatar
GreekDrifter91
ia there a way to manual unlock the passenger door?
what about the hatch? more important at the moment, i have the ecu out and the battery unplugged. any way to pop the hatch? dont feel like plugging both back in. just to get into hatch... doing some service on my car and thats whay they are unpluged.
Old Mar 18, 2013 | 06:27 PM
leaf_fan_1988's Avatar
leaf_fan_1988
There's a wire under the back seat.
leaf_fan_1988
sorry more info; there's a manual release cord under the back seat, you just pull it and it pops the hatch.
Old Mar 18, 2013 | 06:42 PM
rkw's Avatar
rkw
Not from the outside, if that's what you're asking. From the inside, the first pull on the door lever.
Old Mar 18, 2013 | 06:48 PM
Braminator's Avatar
Braminator
To unlock manually
In the event of an electrical malfunction,
you can also unlock the tailgate manually.
1. Fold the rear seat bench upwards
2. Pull the ring.
The tailgate is unlocked.
Old Mar 18, 2013 | 06:51 PM
Braminator's Avatar
Braminator
Old Mar 18, 2013 | 07:21 PM
GreekDrifter91
oh didnt know that, but never noticed it before when i had the back seat up, will have to check again. but if passenger door is lock you cant unlock it?
Old Mar 18, 2013 | 07:28 PM
Braminator's Avatar
Braminator
Sorry about the small pic.
Old Mar 18, 2013 | 07:42 PM
ZippyNH's Avatar
ZippyNH
If I recall, one of the "quirks" of the 2002 (that was fixed in later years) is the doors need battery power to operate fully...
Just kinda remember hearing something and thought "that's crazy" and my mechanic said something along the lines of...well, its a 2002...they have a TON of odd quirks..."
Goes back to the 2002 was basically a clean sheet design from 2 different design teams...some things that folks complained about got fixed later...
On 2003+ cars, just pull the interior handle 2x to open...but still no exterior key to manually unlock it....
2005+ cars, and any car "modified" by the dealer has a pull cable under the rear seat to open the trunk...just for the reason you are having...lets you open the trunk without battery power.
The modification is pretty easy if you want to DIY' it for future use.....just a drill a hole in the lower latch portion, and attach the cable, then run it, and leave it under the seat...
Just look at a car with the mod to find the right spot to drill the hole...maybe somebody can provide a pic...not sure I have ever seen one posted!!
Old Mar 18, 2013 | 07:46 PM
minibx's Avatar
minibx
From what I read some early models did not have the cable installed, I hope that your car does have it, I see that you have a 2002 so that could be the case, good luck
Old Mar 18, 2013 | 07:53 PM
Braminator's Avatar
Braminator
I have a 04 build date 12/03 and it is under the seat and was not modified. I still have the original manuals which is where I got the pics and info from.
Old Mar 18, 2013 | 08:01 PM
rkw's Avatar
rkw
Was something unclear in my earlier post? Pull the (interior) door lever that a passenger would use to open the door, and it will unlock.
Old Mar 18, 2013 | 08:03 PM
Braminator's Avatar
Braminator
Old Mar 19, 2013 | 09:38 AM
Yes,
I remember some early MINI not having the cord ? 2002- 2003
Here are some articles about it from back in the day.
https://www.northamericanmotoring.co...rd-ripoff.html
https://www.northamericanmotoring.co...ase-cable.html
They had to buy the cable kit. Best thing if you have early MINI is to check under the rear seat. It you don't have one list of parts can be done.
#29 & #30 plus some hardware.
Also there was an update to the part for also around that time:
http://forum.roadfly.com/threads/663...l-Boot-Release
It you need certain parts let me know. We are really going back in the day on this one !
Hope that helps.
Old Mar 20, 2013 | 09:16 AM
GreekDrifter91
it does not work that why i asked if there as a way to unlock it. if all i had to do was pull the handle i wouldnt be asking the question.
nope dont have a pull ring. looks like ill have to rig something up. its not that hard to get to the battery any way i have the seats folded down so getting to the boot is easy.
Old Mar 20, 2013 | 09:50 AM
Yea, That's what I figured:
What production month / year in your 2002? I find it very interesting that MINI did not have these in those early 2002- 2003 as it must have not been required yet by MINI for regulations.
Let me know if you want to add it , it looks like they were successful from the links with the retrofit so that way you have the option to have the emergency cable in the future.
Just make sure your older part has the loop to add it.
http://www.ecstuning.com/Search/51242754528/ES91986/
Door lock parts: either the cable snapped or the lock itself is broken
Cable for door lock.
http://www.ecstuning.com/Search/51217143538/ES89991/
Door Lock - Left
http://www.ecstuning.com/Search/51200556768/ES88657/
Door Lock - Right
http://www.ecstuning.com/Search/51200556769/ES88658/
Thanks and good luck
Old Mar 20, 2013 | 09:58 AM
rkw's Avatar
rkw
Then the lock mechanism is broken and it needs to be repaired. Driver and passenger doors work the same -- if the door is locked, first pull unlocks and second pull opens door.
Old Mar 20, 2013 | 10:11 AM
GreekDrifter91
are you sure this is for all years?
Old Mar 20, 2013 | 01:10 PM
rkw's Avatar
rkw
Yes, it's the same for all years.
Old Mar 20, 2013 | 01:57 PM
ZippyNH's Avatar
ZippyNH
I recall one of the "quirks" of the 02 was your exact issue...
think the lock was actually changed....a few folks with the early cars have the same issue
sure there is a post listing the 02 quirks.....
Old Mar 20, 2013 | 02:15 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Stupid question: Even with the ECU out, why couldn't he apply 12 v. and unlock the rear hatch? ECU is for engine mgt. only, right?
Old Mar 20, 2013 | 02:37 PM
rkw's Avatar
rkw
If that's the case, then I stand corrected. So a passenger can be locked in? Seems like a serious safety issue.
Locking is controlled by a different control module, not the ECU. 12v applied to the correct wires should allow the rear hatch to be unlocked, but I thought the issue was how to open it when no power is available.
Old Mar 20, 2013 | 02:48 PM
GreekDrifter91
i dont know i tought the same thing till the next day when i went to unlock the car and it didnt so i had to go thrioguh the drivers door in to the back and lift the tray and see battery was still good and it is. havent tryed putting the ecu back in yet though.
Old Mar 20, 2013 | 02:49 PM
GreekDrifter91
maybe over long periods of time it wont work, becasue i ahev locked and unlocked the car with the ecu out using the remote. but not waititng ttill the next day. it was always just maybe an hour.
Old Mar 20, 2013 | 08:02 PM
ZippyNH's Avatar
ZippyNH
https://www.northamericanmotoring.co...mini-jail.html
Yup...here is a thread on it...was fixed with the double pull handles.....
My February 2003 MCS does not do this. I believe this double lock feature was disabled on 2003 and later MINI's. There is a Tech Memo indicating that the dealer can modify the lock to disable this feature. Check with your service advisor and have this dangerous feature deactivated.
Yup, the '03 and later builds have the double pull handles- you cannot lock yourself in. The early stories were pretty horrendous- folks stuck in the boonieis w/ dead batteries, unable to get out of their cars.
Dieseldoctor
R55 :: Clubman Talk (2008+)
Sep 9, 2015 01:17 PM
HogWldFLTR
Sep 8, 2015 05:25 AM
Filmy
Sep 7, 2015 08:27 PM
dandw2
Sep 7, 2015 11:14 AM
dandw2
Sep 6, 2015 03:14 PM
