R50/53 BCM questions : )
Old Feb 25, 2013 | 06:29 PM
joshp912's Avatar
joshp912
BCM questions : )
If my BCM is bad should I get a used one or new? If I get a used one isn't there a good chance it could/will go out on me since this seems to be a fairly common problem? Lastly has anybody ever discected one of these to see if the problem can be fixed?
Old Feb 25, 2013 | 07:42 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You need to get a new one, as putting a used one in can cause many other problems with things not working, including keys, and coding info.
Old Feb 26, 2013 | 07:53 AM
joshp912's Avatar
joshp912
Thanks WMW! I installed your 16% pulley the other day and am loving it : )
Old Feb 26, 2013 | 04:46 PM
mrbean's Avatar
mrbean
Consider getting yours repaired. It's much more cost effective and there's no hassle of coding / re-programming. I've used www.bba-reman.com for other modules in the past and I would highly recommend them. Ask them if they can take care of your BCM.
Old Feb 26, 2013 | 08:52 PM
joshp912's Avatar
joshp912
mrbean how much did that website cost you and what was the turn around time from ship date to back in your hands?? that's cool man thanks never heard of that before!
Old Feb 27, 2013 | 06:32 AM
joshp912's Avatar
joshp912
just talked to bba-reman.com and they said $500ish for recoding and they need it for 6 days
Old Feb 27, 2013 | 07:24 AM
joshp912's Avatar
joshp912
the dealership just told me $65 to diagnose the BCM and $125 to recode it...way good price
Old Feb 27, 2013 | 07:25 AM
Braminator's Avatar
Braminator
Old Feb 27, 2013 | 07:44 AM
Helix13mini's Avatar
Helix13mini
Josh that does not include the price for the Body Control Module. Typically, if the BCM has taken a dump, you can't fix it by re-coding it--you need to replace it and then re-code it. Look at private shops as good alternatives to the dealership--we don't charge a diagnostic fee and we'll code it for $85.
Old Feb 27, 2013 | 08:11 AM
joshp912's Avatar
joshp912
Helix when you say typically do you mean like what 90% of the time?
only reason I ask is the dealership said they would diagnose the problem to see if the bcm can even be "re-coded". i assume they would not charge me for re-coding if they told me that it needs to be recoded and then it does not work? then again...
Old Feb 27, 2013 | 09:14 AM
Helix13mini
Like 100%, for us at least. I've never seen a BCM malfunction get fixed by re-coding. They very well may have been, I've just not seen it.
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
PSU 98
Sep 11, 2015 11:20 AM
cinnabun
Sep 11, 2015 05:55 AM
marc0011
Sep 10, 2015 10:04 PM
