R56 Clutch jitters
Old Feb 20, 2013 | 01:52 PM
millerb7's Avatar
millerb7
Clutch jitters
Been driving a manual my entire life, and I have to say my MCS is one of the worst clutches I have ever driven. The car itself is super fun, but the clutch from a stop --> 1st and 1st --> 2nd are horrid. No matter what I do, I get this "herky jerky" jitter in the car. I have tried everything. From 2nd --> 3rd it is MUCH better than 3rd on I don't notice it at all.
Thoughts on this? Car is a 2013 MCS with about 4k miles. I thought at first the clutch just need to break in... but I swear my 2012 Wrangler has a smoother 1st --> 2nd than this thing. I cannot get a smooth 1st --> 2nd for the life of me.
IF I hammer the gas when I'm releasing clutch I can get a decent shift... but it shouldn't be like that.
Any known clutch issues with the 2013 MCS's? I'm going to be bringing it into the dealer in the next week or two.
SIDE NOTE: The "jitter" is just that, it's not a crazy jerk or anything... it's sometimes barely there, but I can feel it about 95% of the time. Passengers can't always tell, but I think that's because I'm a little more in tune with the car since I drive it daily.
Am I just going nuts?
EDIT: Also, I only get the jerk as the clutch is near the top, almost fully released. The last inch or so is where the jerk comes in.
Old Feb 20, 2013 | 02:23 PM
MNIPWR's Avatar
MNIPWR
Dual mass flywheel I would assume. Learn to shift different.
Old Feb 20, 2013 | 02:26 PM
millerb7's Avatar
millerb7
Pointers?
I already feel like an ***. I've been driving manuals for 12 years. No issues. Until now.
Old Feb 20, 2013 | 02:27 PM
MNIPWR's Avatar
MNIPWR
It would get me every once and a while, Just make sure the clutch is loaded before you hit the gas.
Old Feb 20, 2013 | 03:13 PM
bmx045's Avatar
bmx045
I thought the same thing, until I started releasing the clutch a hair slower when going into second. I don't press the gas between shifts to preload the engagement, although I have been told to not let the RPM's drop as much between shifts. I find that going from 2nd to 3rd is a lot smoother in general like you said. 1 to 2 is the weird point.
Old Feb 20, 2013 | 03:15 PM
Btwyx's Avatar
Btwyx
That sounds like what you need to do than. If you've got the right engine revs it'll be smooth.
Do you have the sport button on? I can't make a decent shift without the sport button. You won't have to hammer the gas so hard to get the same effect.
Old Feb 20, 2013 | 06:59 PM
blakeslee_a's Avatar
blakeslee_a
Agreed in my 2010 mcs I can shift much smoother with the sport button on just because of the better throttle response, without sport I do sometimes get some jerking/bucking when I did what I thought to be a clean start/shift
Old Feb 20, 2013 | 07:39 PM
cfrea's Avatar
cfrea
Your clutch may be defective. I have the same issue. You're probably experiencing clutch chatter.
I drove my car, then another one with the same mileage and it was buttery smooth. Have MINI look at it
Old Feb 21, 2013 | 08:12 AM
bmx045's Avatar
bmx045
Anyone else notice hard shifting into 1st when the engine is cold? It's not as smooth as one would like....kinda notchy, seems to get better as I drive for a few minutes...I suspect the mt trans must be a scavenging or pick-up style lubrication system
Old Feb 21, 2013 | 09:55 AM
muzak's Avatar
muzak
For those with a jerky 1st --> 2nd, try shifting earlier. Almost immediately. Works for me and I've always thought the car was jerky while rowing the first few gears too. It's smoother with the sport button off as well.
Old Feb 21, 2013 | 06:52 PM
fast fun 2's Avatar
fast fun 2
My 2010 Justa is the same way....my friends laugh at me because of 1st to 2nd...everything else is cake. Downshifting into 2nd takes a decent jab of throttle to be smooth too...even at 20mph
Old Feb 22, 2013 | 05:53 AM
millerb7's Avatar
millerb7
Glad I'm not the only one
Old Feb 22, 2013 | 06:00 AM
richardsperry's Avatar
richardsperry
Install a FES AutoSport module and never have to think about pushing a button again.
As for the clutch. My 2010 S is fine, but trying to drive my friend Vic's 2012 S is a problem. Appearantly BMW/MINI started putting in self adjusting clutchs and the thing doesn't engage until it's almost fully released. It's horrible... If they are all like that, I won't be buying any new Mini...
Old Feb 22, 2013 | 06:16 AM
NJ Mini's Avatar
NJ Mini
The catch point where the clutch engages is really high for these cars which can make it a pain to get used to intially. Especially if you have mutliple manual cars in the house and frequently switch from other stick-shifts to the MINI.
Also, there had been an issue for a while where many of the flywheels used were slightly warped. I had to have my flywheel + clutch replaced at 2,500 miles due to shaking in the pedal every time the clutch was being engaged.
Old Feb 23, 2013 | 02:05 AM
MNIPWR's Avatar
MNIPWR
So as much as I wanted to blame you for this I switched back to the stock map and with this OS Giken clutch I uhhh... uhhh.. stalled a couple times. This non-linier throttle is terrible.
Old Feb 23, 2013 | 04:48 AM
Twstgrp's Avatar
Twstgrp
I have a 2008 46,000 miles and had the clutch done last year. The clutch was smooth until it started to slip under hard acceleration in 6th. When I had it replaced, the clutch disc was not worn out but the Flywheel surface was destroyed. I had a new OEM clutch kit and flywheel put in, and its done the judder dance ever since. I have to over rev slightly and slow down the engagement on launch. These flywheels are very light and I wonder if I should have gotten a steel flywheel and gotten a 5 blade clutch plate to offset the weight gain. Any Autocrossers used this set up?
Old Feb 23, 2013 | 10:51 AM
MNIPWR's Avatar
MNIPWR
The stock clutch and flywheel weigh nearly 40 pounds. The jitters are due to the springs in the flywheel.
Old Feb 23, 2013 | 02:21 PM
Twstgrp's Avatar
Twstgrp
Springs in the flywheel? It's new and the old one never did it. I'm confused.
Old Feb 23, 2013 | 02:36 PM
MNIPWR's Avatar
MNIPWR
There are springs in between the two plates of the flywheel. Since you were used to the old worn down springs getting used to the new one is going to be different. I can barley drive my car with the stock throttle map and aftermarket solid flywheel.
Old Feb 23, 2013 | 06:37 PM
Twstgrp's Avatar
Twstgrp
Guess I'll have to adapt. Certainly there is no other car I want that fits my budget. So the new blue version 2013 I have ordered will just have to put up with me!
Thanks for the info. I thought dual mass meant that one part was aluminum and the friction surface was steel. I can wrap my head around this, I remember clutch plates had springs to dampen chatter. I suppose this is meant to serve a similar purpose.
Old Feb 23, 2013 | 08:16 PM
Slave to Felines's Avatar
Slave to Felines
... I wonder if I should have gotten a steel flywheel and gotten a 5 blade clutch plate to offset the weight gain. Any Autocrossers used this set up?
Never in a MINI, but every "puck" type clutch disk (the pieces of friction material on those five arms are called pucks) I have ever tried or even heard of are on/off switches. There is zero modulation, and it is not easy to get them rolling without stalling.
Old Feb 24, 2013 | 01:24 AM
MNIPWR's Avatar
MNIPWR
Yeah they are there to get rid of the snappiness of the clutch engaging. And make accelerating and engine breaking less harsh. You tube it. Tht can explain better then me over text.
Old Feb 24, 2013 | 05:59 AM
k_h_d's Avatar
k_h_d
It would be nice if you could feel the engagement point a little more. I find that I don't like sport mode unless driving really aggressively. On the street there is not enough safe areas to drive aggressively enough... On the autocross course I think I do prefer the sport button. The throttle is just to touchy. Its like past the first 1/2 inch of travel there is no modulation to the throttle, I think it goes to WOT after just a little bet of movement.
Old Feb 25, 2013 | 03:44 AM
MNIPWR's Avatar
MNIPWR
The stock map is not liner I find it annoying.
Old Feb 25, 2013 | 11:07 AM
Twstgrp's Avatar
Twstgrp
Nice explanation
http://youtu.be/DbvP5EvpUbA
Thanks , before this I understood but, now I overstand!
drrigg
May 27, 2022 03:31 AM
eliseo1981
Nov 2, 2015 11:24 AM
unxpectederror
Oct 22, 2015 12:16 PM
Oct 1, 2015 12:13 PM
Sep 28, 2015 09:13 AM
