Drivetrain Custom magnaflow muffler question
Old Feb 11, 2013 | 09:46 AM
RobMuntean's Avatar
RobMuntean
Hey guys,
I have a magnaflow muffler I bought a little while back and now I'm looking for tips to put on it. My issue is that I'm not finding what I want. I have a 2.5 inlet and 2.5 outlet oval body 14" muffler. I am sticking with a 2.5" straight pipe replacing my 2nd cat(not going to go with 3", heard stories on it).
I am curious to know will this part 35136(tips) fit with my muffler, part #12158. Thanks guys!
Rob
Old Feb 11, 2013 | 10:10 AM
countryboyshane's Avatar
countryboyshane
You have a dual outlet muffler? This is what I found under Magnaflow:
http://www.magnaflow.com/02product/d...rtnumber=12158
Old Feb 11, 2013 | 10:16 AM
RobMuntean's Avatar
RobMuntean
Correct that's the one I have! I just don't know which tips will go good on my muffler. I want the slash ones but I won't be mad if I can't fit it. I found a few on the website but my muffler has the 2.5 outlet while the tips are 2.25. That wouldn't even fit:-/.
I made the right choice going with a 2.5 inlet/outlet over the 3", right?
Old Feb 11, 2013 | 12:37 PM
gerry2153's Avatar
gerry2153
I think a single outlet would be better, and then use a dual tip....
I dont think the two outlets off the muffler will line up correctly. . .
Old Feb 11, 2013 | 03:11 PM
countryboyshane
Rob,
What I'm wondering is if the two tips will fit out the recess in the rear bumper facia. Have you verified this? I've never seen anyone with two separate outlets that far apart before on the R56.
Old Feb 11, 2013 | 03:35 PM
sooper_cooper's Avatar
sooper_cooper
It should work no problem, I have a similar one but with 2.5" inlets and outlets:
I'm using these tips and it all fits perfectly under the bumper:
http://www.magnaflow.com/02product/d...rtnumber=35121
Old Feb 11, 2013 | 04:51 PM
RobMuntean's Avatar
RobMuntean
I want THOSE tips. But quick question, are you running a 2.5" or 3" straight pipe?
Old Feb 11, 2013 | 04:54 PM
RobMuntean's Avatar
RobMuntean
Rob,
Shane,
I've seen many people run the 35121 tips on the mufflers with 4 inch separation. It looks really nice. I just want to get it polished since our roads here in Michigan suck with all the salt and crap.
Old Feb 11, 2013 | 05:05 PM
sooper_cooper
I went with a 2.5" straight pipe. I think 3" is overkill for a Mini. Plus, the 2.5" matched the size of my Riss downpipe.
gerry2153's Avatar
gerry2153
Can you show a pic of what it looks like ???
Old Feb 11, 2013 | 05:16 PM
sooper_cooper
Here's a couple of posts where I attached pics. The tips fill out the exhaust cutout perfectly without touching the edges:
https://www.northamericanmotoring.co...94-post64.html
https://www.northamericanmotoring.co...3-post152.html
Sounds good too!
Old Feb 11, 2013 | 05:30 PM
RobMuntean's Avatar
RobMuntean
Shane,
What are you running, a 3" or 2.5" straight pipe? I'm gonna tune the car this spring/summer, I'm just curious what would flow better with the tune.
Old Feb 11, 2013 | 07:12 PM
gerry2153's Avatar
gerry2153
Sounds good too!
Any droaning ... thinking of going this route also... but I already have an annoying droan ....
Old Feb 11, 2013 | 07:39 PM
sooper_cooper
Keep in mind I was running completely catless and without the stock resonator, so drone was horrible. It sounded great but I couldn't take that amount of drone on the highway.
I added this in as a resonator and it solved the problem:
http://www.moroso.com/catalog/catego...?catcode=35054
Cuts out the drone but still sounds fantastic, low and mean.
Old Feb 11, 2013 | 08:15 PM
gerry2153's Avatar
gerry2153
thanks - I was also looking at free flow resonator from vibrant
Old Feb 12, 2013 | 06:30 AM
richardsperry's Avatar
richardsperry
Or you could do what I did and buy a JCW downpipe back takeoff for $200. Problem solved.
Old Feb 12, 2013 | 09:39 AM
RobMuntean's Avatar
RobMuntean
I'd rather not. I love the sound and minimal gains from the custom exhaust from the magnaflow muffler. I already bought the muffler so it'd be cheaper to do what I want.
blacklistedmini
Oct 27, 2017 10:31 AM
12R58JCW
R58 :: Coupé Talk (2012+)
24
Sep 8, 2015 01:40 PM
honderpilot
Aug 31, 2015 02:53 AM
JPMontes3
Aug 24, 2015 07:15 AM
jrezzo
Aug 9, 2015 10:32 PM
