Suspension Searched, now I need some help!
Old Feb 1, 2013 | 09:14 PM
rjtrout2000's Avatar
rjtrout2000
Alright, I just picked up a new daily driver (literally, 2013 mini cooper) i had it speced out with the sport suspension as it was offered at no additional charge. It is a nice compliant everyday suspension, but I would like ut to be a bit lower...
So...which spring works best with these shocks? I looked at doing TSW springs since that is what I have on my R50 ...but what are your impressions on them? The other springs I looked at are NM Engineering, H&R, and Swift. All opinions are welcome and I am proud to be part of the R56 club now too
Old Feb 3, 2013 | 03:56 AM
rjtrout2000
No one huh? Just looking for a mild drop that is daily driveable for the car. If it doesn't exist (a spring that plays well with OEM sport shocks) then I may omit lowering the car altogether! I would like to get rid of a little wheel gap though...
The NM RS Alpha springs seem to come highly reccommended.
Old Feb 3, 2013 | 09:05 AM
Melangell's Avatar
Melangell
TSW.
I just had them installed and am already loving them.
Old Feb 3, 2013 | 09:09 AM
dannyhavok's Avatar
dannyhavok
Congrats on the new car! Are you keeping the R50? Stripping and track prepping it?
Old Feb 3, 2013 | 10:37 AM
countryboyshane's Avatar
countryboyshane
Lots of guys running around on NM-eng lowering springs in the local MINI club but without changing dampers, which is guaranteed to give you a more jarring ride. TJ at Detroit Tuned has done NM springs and Koni Yellows believe. I would give the guys at Detroit Tuned a call.
Old Feb 3, 2013 | 05:10 PM
rjtrout2000
Thanks sir! Yes, Otis is still mine and he is going into "Battle Mode"
Old Feb 3, 2013 | 05:17 PM
rjtrout2000
Originally Posted by Melangell
TSW.
Pics would be appreciated
Old Feb 5, 2013 | 05:49 PM
mbwicz's Avatar
mbwicz
I put the TSW springs on my sport shocks. Only dropped the car about 1/2" (looks better than stock but not lowered). Ride was pretty rough, then I figured out that I didn't have much travel and was riding on the bump stops. I then swapped out to a set of WMW bump stops, and the ride was better. I ended up trimming 1/4 coil off of the front because the front sat higher than the rear on my car. I then swapped to a set of the standard Cooper S shocks, and the ride is more compliant (still stiff) for my daily driver.
Check out my sig picture, it is accurate for ride height. Supposedly the NM's are a bit lower, but I haven't tried them (have a set, but don't feel like changing shocks right now).
Mike
Old Feb 5, 2013 | 06:41 PM
MikewithaMini's Avatar
MikewithaMini
My son's '07 S with NM alphas with stock shocks. He says it's great. We also put on an 19mm sway bar and lower control arms. Tires are 215x45x17 on stock wheels.
Old Feb 6, 2013 | 05:33 PM
rjtrout2000
It sounds like the NM RS Alpha springs are the way to go! !! The drop looks perfect too. Just have to figure out if premature suspension wear is worth the aesthetic boost...d
Old Feb 6, 2013 | 05:46 PM
MikewithaMini
I also have NM on my 08 with Koni Yellows. Better ride than the original Sport Suspension it replaced. Sway bar, lower control arms and a good alignment handles great for me. Few pics in my gallery.
Old Feb 7, 2013 | 03:30 AM
rjtrout2000
From everything I have read, the NM RS Alpha springs seem to be solid for daily driving, even with OEM sport shocks. I think these are what I am going to stick eith. When I drop Otis off today for his final suspension fitting, I will ask Way his professional opinion between NM and TSW for my needs. Honsestly, the sport suspension from the factory feels terrific to me! Very compliant for everyday use. Ride height is the only thing that kind of bothers me :/
Old Mar 31, 2013 | 01:10 AM
KilmerPT's Avatar
KilmerPT
Curious how you like your new suspension setup?
kevins
Sep 23, 2015 01:46 PM
eliseo1981
Sep 18, 2015 10:40 PM
The Rossness
Sep 17, 2015 03:06 PM
HaveATank
Sep 16, 2015 08:32 AM
Sep 4, 2015 08:25 AM
