Idle issues
Old Jan 29, 2013 | 02:06 PM
hell0kitty's Avatar
hell0kitty
Idle issues
I have a 2012 Countryman S All4. Not too long after I first got it, it started trying to stall out at the first stop sign leaving my house in the morning. By the second stop, the idle was fine. It also idles fine when it is first cranked before I leave the drive way. The issue happens with/without the heat or AC, in and out of gear, full or nearly empty gas tank, etc.
This didn't happen every day in the beginning but now it does. I have taken it in to the dealer 2x now. The computer shows no codes. At first they wrote it off as a fuel problem but I always use premium. They sent me home with fuel additive which did not help. The second time, they cleared all the adaptive driving stuff and told me to drive it hard. That has made it worse. It now nearly stalls at the first stop sign every morning and sometimes again at the first stop sign after I leave work. Has anyone had a similar issue? Any idea what it might be?
Old Jan 29, 2013 | 04:18 PM
52804x4's Avatar
52804x4
Have you had the thermostat recall/TSB taken care of yet?
Old Feb 21, 2013 | 10:44 AM
hell0kitty's Avatar
hell0kitty
I am taking her in tomorrow morning so I will ask about the thermostat recall. That sounds reasonable since it only happens first thing in the morning when the engine is cold.
Old Feb 24, 2013 | 07:05 AM
fused's Avatar
fused
I had the defective thermostat temp switch or whatever that recall actually was for. No codes but replacing the item fixed the problem...
Old Mar 21, 2013 | 10:28 AM
hell0kitty's Avatar
hell0kitty
I cannot believe it has been a month since I last posted to this thread. I have taken the Countryman back in 2x in the last month for a week each. They say they are not to be able to replicate the issue. They did replace the fuel pump but not the temp sensor. I picked up the car an hour ago and it did the rough idle on the way home. They claim they cannot replace the part until the recall applys to my specific car or it throws a code.
Old Mar 21, 2013 | 01:11 PM
mrlogsd's Avatar
mrlogsd
I had a similar issue with mine turned out the cooling system was not holding pressure due to a worn gasket on the thermostat housing. Replaced it and all is well now. The dealer can do a pressure test on it.
Old Mar 28, 2013 | 02:32 AM
Traprock's Avatar
Traprock
I've had the same issue with m '12 All4 when it's cold. Been to the dealer a for this among other things but they say they can't duplicate the problem and suggest using only quality premium fuel (duh!). Very frustrating when its below 30F. When I back out of my driveway and put in 1st I'm facing up a steep hill and that's where its really noticeable.
Also when leaving work, I get the same thing until I've passed my 2nd or 3rd stop siignal.
Old Apr 24, 2013 | 02:45 PM
kazyn's Avatar
kazyn
I've had the same problem. Sensor replaced with first service helped a little but not much. 15k miles now 4 visits to the dealer and no help from their side.
Old Jun 12, 2013 | 10:52 PM
MINItitan's Avatar
MINItitan
Same issues... Just had it at the MINI dealer. They replaced the high pressure fuel pump under warranty. (2011 ALL4). So far so good...
iggi
18
Feb 9, 2026 01:00 AM
gmcnaugh
Oct 27, 2018 03:42 AM
Marco Guardado
Sep 15, 2015 01:22 AM
robbiedowns22
Aug 25, 2015 12:20 PM
Lt. Dan
Aug 10, 2015 08:23 AM
