R56 M7 or DDM intake?
I have the AGS-R and really like it. Only issue has been clearance. With a boost tap adapter(for Forge's BOV kit and/or boost gauge), the AGS-R doesn't sit right. The boost tap adds some height and presses against the bottom corner of the AGS-R. 2 options to fix: Either cut a hole on the AGS-R cover itself to clear the boost tap adapter OR just let it sit on it and get washers to reach the mounting points for the AGS-R. Not a deal breaker for me.
https://www.northamericanmotoring.co...-from-aem.html
I just received mine yesterday (so obviously, top of mind!). Plan to install this weekend. And it's certainly less expensive than the full on DDM.
If you've already ruled it out, then of course never mind.
Sent from my iPad using NAMotoring
I have the DDM RIS. I went this route because I wanted the hood scoop to become functional and I wanted to maintain a semi-stock, under-bonnet look. The AEM wouldn't have worked for me because of its appearance and size.
Upon first glance, it doesn't appear that I have done anything under the bonnet, except for the addition of a strut bar.
Damn no way...I think I tried them, around last xmas as well, and they told me it would be several months waiting time. Pretty much just gave up at that point. I'm at the point of switching intakes just so that I can fit another strut bar....But I love my DDM in combination with the m7 hood scoop. Always ambient or lower temps when moving.
Sep 22, 2015 02:05 PM
