Stumble/Hesitation/Choking when I blip throtle
Old Jan 16, 2013 | 08:56 PM
Xtrackdog's Avatar
Xtrackdog
The car stumbles, or hesitates, or chokes when I blip the throtle from idle. If I gradually depress the throtle the revs go up smooth. It is only when I blip the throtle. Problem is getting the revs up from idle if I depress the throtle suddenly.
As a result, I always have to put it in 1st gear when coasting from a stop sign (no I don't always come to a full stop). Used to be able to put it in second and go.
Car starts fine when cold.
Goes through the gears fine, nice and crisp
Idle is steady
No hesitation accelerating on the highway (when the revs are up)
It is my wife's car, so I don't drive it often. We just installed a catback and I was blipping the throtle to hear the new exhaust. That's when I felt the symptoms.
The problem I am told has been going on for a while.
Any ideas or comments to point me in the right direction is appreciated.
Old Jan 16, 2013 | 08:58 PM
Xtrackdog's Avatar
Xtrackdog
I was going to get a canned flash, but would rather wait until I get this sorted out.
Although, the flash may correct the problem if it is an ECU issue.
What do you think?
Old Jan 16, 2013 | 09:47 PM
GreekDrifter91's Avatar
GreekDrifter91
just try resetting the ECU its easy and will probably fix your problem.
and are you trying to take off from a stop in second? thats not good at all.
Old Jan 16, 2013 | 09:57 PM
Xtrackdog's Avatar
Xtrackdog
#Still rolling.
I've done the reset. But will try again.
Old Jan 16, 2013 | 10:00 PM
Xtrackdog's Avatar
Xtrackdog
The research I've done seems to point to:
1. Vacuum leak
2. Timing, air/fuel
3. Plugs/Wire - Less than 10k
What would you do to troubleshoot? I have ordered a PCV valve from the dealer.
Old Jan 16, 2013 | 11:25 PM
SniperDetailing's Avatar
SniperDetailing
Probably a weak spring in the bypass valve. Does the car seem to jerk slightly when you depress or release the throttle abruptly from a low-throttle angle?
Old Jan 17, 2013 | 01:09 AM
minsanity's Avatar
minsanity
Check fuel distribution/pressure: filter & pump.
Old Jan 19, 2013 | 05:45 AM
MINIFatherFigure's Avatar
MINIFatherFigure
From: Perth West Australia in an industrial unit with my numerous cars.
I'd go for vac leak, TPS and fuel pressure/filter. Plugs etc non starter as you have no other symptoms.
Old Jan 19, 2013 | 12:01 PM
drifter.locus's Avatar
drifter.locus
I think minisanity has a good point.Check fuel pressure. Thats the same thing my truck did when the fuel filter was dirty and it took me a yr to believe someone and try it. We always start with the hard stuff.
Old Jan 19, 2013 | 11:37 PM
minsanity's Avatar
minsanity
Went thru everything to cure mine of it. From plugs, wires, gas, injector cleaning, vacuum leak check, BPV, harmonic damper change. Checked rail pressure, way low. Replaced rail pressure regulator, still no go. Filter, no go. Finally, checked pump, had a torn in-tank fuel hose from pump to filter....Did it step by step in chronological order above. Wished I reversed it. The pump & filter had never been previously touched since new. One of those unexplainable mysteries in life.
Old Jan 22, 2013 | 11:20 AM
Xtrackdog's Avatar
Xtrackdog
Update: Had a GIAC flash done for $400, which has fixed the issue.
Apparently, the stock ECU was unable to compensate for the combination of engine upgrades I have on the car.
15% pulley, CAI and Catback, MSD wires/coil and colder range plugs.
I would describe the flash as having smoothed out the way the car runs, no monster power kick in the pants experience. Realistically you can only make so much HP/TQ safely from a 1.6 4 cylinder engine. I am satisfied.
I'll be focusing on handling upgrades next. Already have front stress bar, cabrio braces, under brace, 22mm sway bar. New tires, lighter wheels and shocks next.
Thank you for all your responses.
Old Jun 20, 2018 | 04:27 PM
Docsigns's Avatar
Docsigns
I have the same issue but I have no upgrades on my vehicle. Got a fuel filter and waiting on the fuel pump to come before I install everything.
Old Mar 22, 2019 | 07:59 PM
haKKaMeE's Avatar
haKKaMeE
Hi All
Good day. I have the same problem for my R56 LCI model as well. Replaced new fuel pump, fuel filter and HFPF. Still facing the above issue. Only upgrade to the car is Wagner Tuning intercooler. Thanks.
Old Nov 30, 2022 | 11:42 AM
drpetercsapo's Avatar
drpetercsapo
Hello! Have the same issue. have you sorted it out?
scfiveo
Sep 27, 2019 02:27 PM
signcarver
Jun 7, 2011 09:52 AM
SpringMountain
Driver's School
Mar 22, 2009 12:54 AM
SpringMountain
General Discussion
Mar 1, 2009 05:28 PM
smcfamily
Aug 8, 2003 06:14 AM
