HELP! Car Apart cant find Oil Leak
Old Nov 10, 2012 | 12:03 PM
ToXIc's Avatar
ToXIc
was hoping my 1st post would be an intro thread but got an unsuspecting problem...
took apart the mini for what i thought was the oil feed line leaking but it doesn't appear to be that..
what can it be?
Old Nov 10, 2012 | 12:19 PM
ToXIc's Avatar
ToXIc
i think it coming from somewhere back here
Old Nov 10, 2012 | 12:44 PM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
It's the oil filter housing gaskets. We have just started to see them, so we started to stock that set. It's an easy swap at the point your at. You will also get coolant out of the car at this point also. HAVE A PAN READY.
Chad
Detroit Tuned.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Nov 10, 2012 | 12:56 PM
ToXIc's Avatar
ToXIc
dang... really wasn't prepared to go that far.. by chance do you have a DIY? and a link to the gaskets?
Old Nov 10, 2012 | 02:00 PM
Detroit Tuned
Vendor - 15 Years
remove the three bolts, remove gaskets, clean up everything, add new gaskets, reinstall bolts. tighten to 7-9 ft lbs. i don;t have a link but the i think the gasket is 20 bucks. you need #5.
http://www.realoem.com/bmw/showparts...30&hg=11&fg=30
Old Nov 10, 2012 | 03:21 PM
ToXIc's Avatar
ToXIc
thanks for the advice.. i ended up putting everything back together since it was only spotting oil... i'll probably look for a shop to fix it..
Old Jan 8, 2014 | 11:59 AM
ToXIc's Avatar
ToXIc
resurrecting this thread..
never got around to fixing the housing seal because when it warmed up the leak went away.
now thats its cold again the leak is back and now leaking way more than before...
i came across a thread (its from another mini site/forum so i dont know if i'm allowed to put a link) that stated you should change the entire housing because the leak is from the housing warping and not really the seals.
has anyone just changed the seals and have this fixed the problem?
Old Jan 8, 2014 | 12:09 PM
I just did the seals. Fixed the issue. Make sure you clean the area of oil residue and coolant and then bolt it back together with a new gasket set. I did an oil change afterwards and add more coolant / re-bleed the air out of the coolant system. To make sure things are clean.
#5 in the picture, that goes against the block, they seep a little bit when the engine is hot.
Gasket Set #5 Part number.
http://www.ecstuning.com/Search/SiteSearch/11427557009/
I also would recommended checking the oil return line ( connects to the housing then to the turbo ) and the oil feed line ( on the engine and connects to the side of the housing. Since you are down there. Oil return line leaks from the top, and oil feed line leaks up near the turbo. While you are there.
Turbo Oil Return Pipe Part # 11657583838
http://www.ecstuning.com/Search/SiteSearch/11657583838/
Turbo Oil Pipe Line - Supply
http://www.ecstuning.com/Search/SiteSearch/11657534454/
07119963151 x 4 for the gasket
07119905176 x 2 for the banjo bolt.
OEM MINI Coolant: Mix 50/50 with distilled water.
http://www.ecstuning.com/Search/SiteSearch/82140031133/ES196253/
Oil Change kits:
MINI Oil Service Kit Gen 2 - Priced As Kit
http://www.ecstuning.com/Search/SiteSearch/11427622446KT/
Old Jan 8, 2014 | 01:58 PM
ToXIc's Avatar
ToXIc
thanks for the info..
KrisMiss
Jan 3, 2016 02:02 PM
johntotah94
Oct 19, 2015 02:20 PM
wind715
Aug 11, 2015 07:56 AM
kwijmbo
Aug 5, 2015 09:00 PM
