Proper Lug Torque Specs?
Old Nov 6, 2012 | 07:12 PM
reyoasian's Avatar
reyoasian
Hi guys,
I have a 2012/2013 (really not sure) Mini Cooper Classic (Knightsbridge) with stock 16" wheels and I'm changing them to 15" for snow tires (on steel rims with stock lug nuts)
I am wondering what's the proper torque spec to the lugs? Since I'm going to DIY I want to make sure I torque to proper settings so I don't put myself in danger on the road, nor do I want to break the studs.
I've searched around and found posts that say 85, 103 etc. So no definite answer. Hopefully I can get all the MC guys here to chime in and lend me some knowledge.
Old Nov 6, 2012 | 07:16 PM
willieboy's Avatar
willieboy
85 is fine. 103 is for the GP.
Old Nov 6, 2012 | 08:02 PM
Btwyx's Avatar
Btwyx
103 ft-lb (140 Nm) is the proper spec for the larger bolts, which come with a 2012/13.
85 was the spec for the older small bolts which havent' been used since 06.
Old Nov 6, 2012 | 08:53 PM
Eddie07S's Avatar
Eddie07S
Just did wheels on a 2011. 103.3 ft-lb is what is stated in the owner's manual. There is actually a lot of good info in that little book.
Old Nov 7, 2012 | 06:37 AM
reyoasian's Avatar
reyoasian
What is GP? 103 and 85 seems like a BIG difference...
I have the black bolts...any idea if that's big or small?
2011/2012/2013 are all the same?
Old Nov 7, 2012 | 06:45 AM
Mini2na's Avatar
Mini2na
The GP was a special edition Gen 1 MINI put out in 2006. There will be another for the Gen 2 MINI as it ends its run.
You have the "big" bolts, so 103 is the spec.
2007 - present should be all the same.
Old Nov 7, 2012 | 07:10 AM
reyoasian's Avatar
reyoasian
I see! so will do 103 Thanks a lot
Old Nov 7, 2012 | 08:08 AM
Bilbo-Baggins's Avatar
Bilbo-Baggins
Don't forget to re-torque them after you have driven 20 miles or so.
Old Nov 7, 2012 | 08:15 AM
reyoasian's Avatar
reyoasian
Yep! Just did it on my IS250........getting the Mini swapped out Saturday!
Old Nov 7, 2012 | 11:48 AM
willieboy's Avatar
willieboy
That would be correct. I should have paid more attention to detail in my reply. I have the older R53 GP which is 103 foot pounds.
Old Nov 7, 2012 | 04:36 PM
Eddie07S's Avatar
Eddie07S
It is all about the bolt size.
The 12mm bolts (Gen 1s) are ~85 ft-lbs; the 14mm bolts (Gen 2s) are 103 ft-lbs. I guess the GPs have the 14mm, I don't know for sure but the torque would say that.
'07s - 2013s with 14mm bolts will all be 103.
I think MINI used a mix of black and gold color bolts of different sizes. Check your owner's manual. If you don't have one and want to measure them, 14mm is just a little smaller than 9/16 inch and 12mm is just a little larger than 7/16 inch.
Old Jan 6, 2013 | 12:00 PM
wsalopek's Avatar
wsalopek
I have an 09' Cooper, non-S...came standard with the 15-inch wheels...my bolts are 17mm.
Old Jan 6, 2013 | 12:20 PM
grgramps's Avatar
grgramps
Could it be that we're mixing bolt size with socket size??
Old Jan 6, 2013 | 12:24 PM
wsalopek's Avatar
wsalopek
Could be...I am talking socket size.
Old Jan 6, 2013 | 12:45 PM
Eddie07S's Avatar
Eddie07S
They all use a 17mm socket.
The "size" that determines the torque is the diameter at the threads. Yours are 14 mm.
Old Jan 6, 2013 | 01:58 PM
wsalopek's Avatar
wsalopek
OK...got it...thanks so much.
theblackfalcon
Oct 19, 2015 05:22 AM
one73ronin
23
Sep 22, 2015 09:56 AM
hydouken
Sep 15, 2015 05:49 AM
papawhiskey
Sep 14, 2015 05:47 PM
cw40342
Sep 2, 2015 06:01 AM
