R50/53 Another diesel rattle
So I started getting the Diesel rattle from the engine a month or so ago. I've been driving it sparingly and got around to doing the tensioner plunger change today. So after I lost half my fingernail getting the plunger bolt off, I pulled it out and it came out extended. It also compressed and extended fairly smoothly. That's the first moment, when i thought, oh God, please don't be the supercharger.
I'm not the the most mechanical person, but I can follow a Bentley manual. Sooo, as I understand it, a dead plunger should be stuck shut, right? Before I can fire her back up though, i need to know it's safe to. Since my plunger came out extended, there was no problem putting the compressed plunger back in. All the directions I've seen require a pry bar or turning the crank to get their plunger back in or tension the chain correctly before starting up. Since my compressed plunger went right in, am I good to fire her up? Thanks as always.
ok then, what's the best way to check the SC? Stethoscope? Haven't seen any temp spikes yet.
This is an 03 MCS with 80k.
This is probably the most similar sound from the videos I've seen
http://www.youtube.com/watch?v=rYwGhuXQh7A
https://www.northamericanmotoring.co...night-diy.html
https://www.northamericanmotoring.co...at-change.html
https://www.northamericanmotoring.co...tensioner.html
Same here, '03 MCS and last year the diesel rattle sound become overbearing. Pulled the SC and waterpump gears were dry of oil
, but the teeth still looked good. Just a week before mine, a guy at work also with an '03 MCS but stock pulley lost his SC WP gears the same way, but his teeth were too damaged to reuse.
Then, at MOTD, I found a company (http://www.imperialmini.com) that had developed a recharger product that replaces the waterpump gear plug. So I got one and it works great! I've done 3 oil flushes without having to disassemble anything
.... and still no leaks detected
, but the teeth still looked good. Just a week before mine, a guy at work also with an '03 MCS but stock pulley lost his SC WP gears the same way, but his teeth were too damaged to reuse.Then, at MOTD, I found a company (http://www.imperialmini.com) that had developed a recharger product that replaces the waterpump gear plug. So I got one and it works great! I've done 3 oil flushes without having to disassemble anything
.... and still no leaks detected Thread
torpeau
Oct 8, 2015 11:10 AM
Jim Ferrell
Oct 6, 2015 08:09 AM
eliseo1981
Sep 30, 2015 07:57 PM
Nicefeet
Sep 24, 2015 06:53 PM
