Suspension Searched, still need help. Eco coilovers with good ride?
Old Sep 24, 2012 | 06:34 PM
therealratfink's Avatar
therealratfink
We have a fully modded 2010 Subaru Sti for racing, this car is more for just grins so we don't need race suspension. I just ordered new tires to dump these terrible run flats as well. We would like to lower it a bit but know springs aren't really the way to go with 55k stock struts. So who makes the most economical coilovers with a stock like ride. Thanks in advance.
Old Sep 24, 2012 | 06:40 PM
Mindspin311's Avatar
Mindspin311
ST Suspension is probably your best bet for price and comfort. They are the same as KWv1's but with a limited warranty (rather than lifetime) and the shock bodies are a different material. Still steel, but a different finish.
Old Sep 25, 2012 | 04:32 PM
therealratfink
I'll look into those. Is that really the only one?
Old Sep 25, 2012 | 04:39 PM
therealratfink
So that'd be these?
ST Suspension 90608 ST Suspension 90608
Old Sep 25, 2012 | 04:48 PM
therealratfink
How are Megans for comfort?
Old Sep 25, 2012 | 05:21 PM
ra2fanatic's Avatar
ra2fanatic
ST's are galvanized steel, so if you're in an area where streets are treated with salt because of snow, they may not be for you because they will rust...
Megans are comfortable. With 32 way adjustable dampening, it's not hard to find the right comfort you're looking for.
Old Sep 25, 2012 | 05:24 PM
therealratfink
Thanks, I wish the st or the kw said the spring rates so I could compare that to the megans.
Old Sep 25, 2012 | 05:36 PM
ra2fanatic's Avatar
ra2fanatic
I'm not sure how ride comfort is on the MINI side, but when I had my E92, the ST's really did feel like they were close to stock feel with the advantage of lowering.
Old Sep 25, 2012 | 05:42 PM
therealratfink
That's good to know. I just wish they had some adjustment.
Old Sep 25, 2012 | 07:29 PM
Mindspin311
Im sure you can call KW USA and ask them about ratesq
Old Sep 25, 2012 | 07:33 PM
therealratfink
I see allot of manufacturers showing 2008+ r56, there's no difference with my 07 right?
Old Sep 25, 2012 | 07:35 PM
therealratfink
Just noticed you have megans in your sig, how do they compare?
Old Sep 27, 2012 | 08:13 AM
therealratfink
Looks like the spring rate on the st is 230 rear ( I think that's about 4.1 k) and the front is progressive. Slightly lower rates then Megan. Can anyone comment on the spring quality between the two?
Old Sep 27, 2012 | 09:02 AM
Jack & Coke's Avatar
Jack & Coke
I was set to buy the KW V1 coilovers. Looks like I will now be buying the ST coilovers. Especially since I live here in SoCal and don't need stainless steel shock bodies.
Old Sep 27, 2012 | 09:07 AM
therealratfink
I'm still trying to choose between st and Megan. I like adjustability in case my wife decided to autocross occasionally.
Old Sep 27, 2012 | 09:09 AM
Jack & Coke
I feel your pain. The Megans seem like a great value for what you get. I won't be doing any racing in my ride and the KW coilovers have great feedback for ride quality. Supposedly the ST are made by KW so we will see. I still might opt for the Megans
Old Sep 27, 2012 | 09:11 AM
therealratfink
LOL Exactly
Old Sep 28, 2012 | 01:20 PM
Sketch's Avatar
Sketch
I'm with ra2fantatic when it comes to Megans, they are phenomenal, especially in terms of bang for your buck.
If you are looking to keep your OEM ride height (or near to it), I would recommend H&R Touring Suspension. These are H&R springs with what are basically re-valved Koni struts repainted in an H&R scheme. They lower about 1.4" all around, and when I had them I found them almost MORE comfortable than stock, with 10x more confidence in the corners. Just my .02!
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Hippiehobbit267
Dec 3, 2019 04:22 PM
Getrieben
Aug 17, 2016 06:32 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
jrezzo
Aug 9, 2015 10:32 PM
