R56 What happened to my pops and burbles?
Aug 17, 2012 | 07:38 AM
It's gone! I drive in sport mode all the time because the throttle response helps with heel&toe, and I LOVE the pops and burbles.
But since yesterday, pops and burbles disappeared... Sport mode button still is making the steering heavier, and throttle sharper... This is so weird!
Anyone with similar experience?
ps: this is a 2011 Cooper S.
Aug 17, 2012 | 08:36 AM
Just a thought but it might be fuel quality. Try using a higher grade maybe that will do the trick?
Aug 17, 2012 | 08:38 AM
Thanks for the reply. I pretty much always get my fuel from the same Chevron station by my office, and I always use the highest grade.
But maybe they had bad fuel in my last fill?
Aug 17, 2012 | 09:16 AM
Was your car up to operating temps? The way the p&b works, it drops unburnt fuel onto the hot exhaust manifold, as far as I understand it.
Aug 17, 2012 | 09:18 AM
Quote:
Originally Posted by
muzak
The car was at operating temps. And I think you're right about how the p&b works.
Aug 17, 2012 | 09:32 AM
Aug 17, 2012 | 10:34 AM
Maybe your car just isn't feeling talkative today.
Aug 17, 2012 | 11:19 AM
JoanieB
I've noticed that mine is variable with some days being louder than others. I haven't tracked it yet to see if there is a pattern.
Aug 17, 2012 | 03:04 PM
Ambient temperature effects my pops & burbles. In about 70 - 80 degrees there are times where I will get an extremely loud pop, almost a backfire. In the high 80's and 90's its usually justs the standard pops.
Aug 17, 2012 | 03:35 PM
a new MINI is loaded with burbles and pops
just so many
you used yours up
a classic has an unlimited amount
Aug 17, 2012 | 06:55 PM
Well, I got my pops back, shortly. Then I got a check engine light. Sweet.
Aug 18, 2012 | 10:21 AM
How I wish I could rid The Dread Pirate of the backfire noises!
Aug 18, 2012 | 11:06 AM
Dunno why but when the AC is on mine doesn't pops, when is worm(70 and up) doesn't pops..
meh
Aug 18, 2012 | 02:05 PM
Love the P&B's. Once in a blue I will get a backfire like pop.
Aug 18, 2012 | 02:06 PM
Did the OP get the codes checked to see what the issue was?
Oct 11, 2012 | 08:39 AM
well mine used to pop and gurgle in the morn cold start but after the sensor bulletin stuff was done it won't accelerate gurgle and pop like prior. now it only does it at temp and when traveling. They say nothing was changed
rob&JCW
Feb 21, 2018 02:41 PM
embiggenedmini
Oct 15, 2015 12:36 PM
rob&JCW
Oct 9, 2015 11:12 AM
bneer
Sep 20, 2015 11:29 AM
MiniChick82
Sep 16, 2015 02:56 PM
