What kind of wheels are these?
Old Aug 7, 2012 | 12:23 AM
anuppercasej's Avatar
anuppercasej
Wondering if anybody can tell me what kind of wheels they are. I like them a lot and would like to find more info about them. Thanks...
http://www.flickr.com/photos/62470767@N06/7731404288/http://www.flickr.com/photos/62470767@N06/7731404288/ by http://www.flickr.com/people/62470767@N06/, on Flickr
Old Aug 7, 2012 | 02:14 AM
minsanity's Avatar
minsanity
They look like Konig REWINDs
Old Aug 7, 2012 | 02:41 AM
BJDavis's Avatar
BJDavis
I think they're Rota's?
https://www.northamericanmotoring.co...-in-stock.html
Old Aug 7, 2012 | 03:23 AM
minsanity's Avatar
minsanity
Cap & spokes look more like Rewinds than Rota RBs
Old Aug 7, 2012 | 10:38 AM
Jim Michaels's Avatar
Jim Michaels
I'll break the early tie. Similar look, but they look to me more like Rewinds. The Rewind spokes seem to be more rounded, while the Rota RBs seem to have spokes that "peak" somewhat facing outward.
Old Aug 7, 2012 | 12:54 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
These wheels are Konig Rewind.
You can tell due to the silver center caps and each spoke is not as tapered toward the center as the Rota RB (dark center cap).
Konig Rewind in Graphite finish silver machined lip
15x7 14.5 lbs offset 40mm or 20mm, about $115-132 each
16x7 16.2 lbs will not fit MINI due to bolt pattern of 4x114.3
Comes in Silver and Graphite finish
MINI uses 4x100 bolt pattern
Rota RB
15x7 offset 30/35mm, about $146 each, offset 25/35mm in gold
15x8 offset 35mm, about $150 each, Royal Gunmetallic/Red/Silver
Hub bore 67.1mm/57.1mm - will need centering ring to fit MINI 56.1mm hub bore
Comes in many finishes- Red, Royal gold, Royal Gunmettalic
Both wheels are gravity cast alloy
Another wheel with a similar "classic" mini look-
Minilite wheels (magnesium shown, 15x6" various offsets)
http://www.minilite.co.uk/products.htm
Old Aug 8, 2012 | 12:28 PM
anuppercasej
Thanks for the responses guys!
So the Konig Rewinds won't actually fit on a MINI?
Old Aug 8, 2012 | 12:47 PM
minihune's Avatar
minihune
For the Konig Rewind you can use it on the MINI but it will have to be the 15x7" size only likely offset 40mm.
I did not find a 16x7 that had the 4x100 bolt pattern, you can search and see if any vendor carries it in that size.
Old Sep 23, 2012 | 08:43 AM
A4Some's Avatar
A4Some
Hey guys, that's my car and yes Konig Rewinds on stock suspension. Just the wheels/ tires alone made a huge difference in the overall handling of the car. I would also suggest the Rota RB 15x8s. They would look awesome.
Camaro108
Aug 25, 2015 02:44 PM
HaveATank
Aug 24, 2015 10:26 AM
brother i
Tires, Wheels, & Brakes
Aug 23, 2015 01:15 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
