R58 Spacers: Pros and Cons
Old Aug 6, 2012 | 10:22 AM
user 837978240's Avatar
user 837978240
General question on spacers.
What are pros of spacers?
Are there any cons?
Old Aug 6, 2012 | 10:35 AM
DneprDave's Avatar
DneprDave
Wheel spacers?
Dave
Old Aug 6, 2012 | 10:36 AM
user 837978240
Yes, sorry about that.
Wheel Spacers: pros and cons
Old Aug 6, 2012 | 11:00 AM
cube17576's Avatar
cube17576
Coordinator :: STLMini
Pros: they push the wheels farther out. Not really necessary with stock wheels, but might be necessary for aftermarket wheels to clear the brakes.
Cons: You have to get longer lug bolts.
Old Aug 6, 2012 | 12:36 PM
ALTAPerformance's Avatar
ALTAPerformance
Wheel spacers allow you to fine tune the off set of your wheels, either aftermarket or OEM. With aftermarket wheels they can also be used, as someone said, to push the wheels out if they hit the brake calipers. Going to a larger spacers may cause tire to fender clearance issues that may need addressed. This is done by trimming on a MINI because of the plastic fenders or by rolling (bending up) the metal fender lip on most other vehicles.
When getting wheel spacers be sure you get hub centric spacers, do not get the universal type as that will put all the stress on the wheel bolts or studs instead of the hub.
Old Aug 6, 2012 | 04:36 PM
user 837978240
Great tips and feedback. Thanks all!
Old Aug 6, 2012 | 10:50 PM
Marioalex24's Avatar
Marioalex24
Props. They look cool when the wheel is pushed out. More aggressive. I have 15mm all around and looks good.
Old Aug 7, 2012 | 03:50 AM
ZippyNH's Avatar
ZippyNH
Cons
More stress on the bearings, so a shorter life, especially when extreme.
A wheels offset is about keeping the weight of the car and how it transfers it to the hub area in specs....a spacer effectivly changes this a bit, but still allows a different wheell to fit that may not met the orgional specs. With a mild, thin spacer, you likely will have minimal issues,just like cv joint life on a lowered car, but start to get agressive/extreme, and things happen....
Old Aug 7, 2012 | 06:34 AM
cct1's Avatar
cct1
Originally Posted by ZippyNH
Cons
This is why some people at the track will give you a look of horror with spacers, there have been some nasty incidents related to spacers...
I don't run them at present ( although my brake hats are a defacto spacer), but I will on my next set of wheels for the track, because of fitment issues, and it's a compromise, if I couldn't, I wouldn't. I will have them custom made hubcentric on one side and wheel centric on the other.
On my daily wheels, no spacers.
Doc Pain
Mar 10, 2021 04:50 AM
OutMotoring
Mar 3, 2017 06:29 AM
theblackfalcon
Oct 19, 2015 05:22 AM
The Rossness
Sep 17, 2015 03:06 PM
MidnightF56
Sep 10, 2015 01:04 PM
